Brake reservoir screw head issue
satchit
I was planning to replace my front brake discs and before starting I wanted to to remove some of the brake fluid from the reservoir as it was way over the top level. I anticipated I would have to push in the pistons and would need the space in the reservoir.
One of the screw heads on the reservoir has got gouged out (I did use a JIS head).
I'm hoping I'll be able to take it out with a straight screwdriver. Is there any other approach which might have a higher chance of succeeding?
I remember seeing a thread about replacing those screws with allen key head screws. I cannot find that thread. Are there any other replacement screws I could find in a hardware store to use here? Or does someone know what terms I could search with to find the other thread?
Any help is appreciated.
Try sticking the flat of a rubber band down in there with a screwdriver ( old mechanics trick)
If that doesn't work, you could use a Dremel and a cutting blade to cut a slot in the screw to use a flat-blade screwdriver.
Since the screw is beveled, might be easier to just replace with an OEM screw and use a small dab of anti-seize on it.
You might also try putting the screwdriver in the head and tapping lightly, but sharply (if that makes sense) then seeing if it will come out. Or sometimes putting torque on the screw while tapping.
Whatever you do, protect your paint. The brake fluid will mess it up RIGHT NOW. Put some plastic over the tank.
(dang) I remember doing this crap back in the early 80's and thought: Can't they engineer these reservoirs better?
Take the best of a chemical and mechanical engineer and make the issue go away? Maybe it has ... in outer space, but not in the civilian domain.
Heck, maybe not use "Phillips" screwheads might solve half the problem.
1 Would try to remove the one good screw and see if you can rotate the lid so as to break the head loose.
2 sharpen a flat head screw driver so it has the widest grip on the bad screw and very sharp biting edges.
3 try tightening and un-tightening alternatively and use some wd40 or equivalent.
Thanks for the picture, that really helps.
Also put the new screws in with some grease in the threads, let us know how you get on.
i have used valve lapping compound in the past
if you try the rubber band make sure to clean off all the WD40
I always pound a beer and whisper the obligatory statements.... "Please work this time" or "She ain't going nowhere" before I begin these types of delicate projects.
(I might also add a very important note, this has NEVER been a successful solution for me in the past)
Note, screw heads on our 'bikes are NOT 'Philips' head, though they look like it.
They are the very-similar-in-appearance 'JIS' screw heads - superficially similar to Philips', but, crucially, a Philips screwdriver wil chew up a JIS screw head (unless the tip of the Philips has been ground away).
For the cost involved, it's WELL worth buying a (or a set of) JIS screwdrivers.
Maybe an impact driver with a JIS bit in it would get it started, provided the screw head isn't already too damaged.
Vessel actually has a JIS impact screwdriver. I have one. It’s pretty cool and would have been perfect for a situation like this.
I have several types of 'impact drivers'... a Vesel JIS screwdriver type, a large manual one with interchangeable bits, and a 20v beast of a machine (great for car wheel nuts!).
But they frighten me... Bearing in mind that our engines are mostly alloy castings (including that brake fluid reservoir), whacking a 'screwdriver' with a hammer onto these castings seems very dangerous to me - a cracked casting seems a likely possibility.
I bought my Vesel impact JIS screwdriver to tackle the casing screws on my Yamaha. The first whack I gave it frightened the life out of me! But I'm a great big 'nervous nelly' anyway...!
I will soon be (gently!) trying the 20v impact driver on these screws, to see if I have better luck.
But 'impacting' with a hammer on some of these castings should be undertaken with great trepidation, imho.
