Hello everyone, I'm back & whining again.
I got around to installing speedbleeders and bleeding the brakes and clutch today. 3 of the speedbleeders worked flawlessly for the brake calipers.
The 4th (for the clutch), got installed and sealed fine. However after the quarter turn and pumping the lever - no fluid came out. I noticed that the fluid was slowly seeping out around the threads when I pumped. I removed the speedbleeder and used the OEM screw to finish bleeding. I noticed that the thread sealant had completely come off this 4th speedbleeder. Basically it seats and seals when tightened fully - but once it is loosened to bleed, the pressure doesn't move the ball, but the fluid leaks around the threads. The OEM screw doesn't have any sealant on it so am wondering if the ball valve somehow is faulty.
I have sent the image to speedbleeder.com asking if there is any way to test the speedbleeder and check if the valve works correctly? Or if it is normal for the sealant to wear off so quickly on the first use. Anyway, I don't think I can reuse this one since all the thread sealant is off. For now I'll just leave the OEM screw on. I just hope the other 3 speedbleeders are fine.
Some of my observations...
1. There is very limited space to install the tube for bleeding the clutch. It took some effort to get the tube on the (speedbleeder and OEM) screw and not have it kink against the starter.
2. My original brake fluids were quite clear - but the clutch fluid was much darker. Supposedly all the fluids were bled in 2018 together - so this was a bit strange.
3. I bought the 946ml bottle of Valvoline DOT4. The fluid I got out into my container after bleeding was less than 200ml - and this would have included some of the new fluid too. This is the first time I was doing it so I wanted to be safe but I think 300ml would be more than enough if everything goes smoothly.
4. It is possible for one person to bleed the clutch fluid with the OEM bleeder. I was getting disheartened when the speedbleeder wouldn't work here - but was relieved to be able to use the OEM bleed screw.
