Any aftermarket Turn signals plug and play?
gretle_2.0
First service completed
Hey guys I want to get smaller and black turn signals for my 2013. I ordered 2014 turn signals and was going to paint them black but they are back ordered for another 4 months….. is there any good decent small black turn signals that are mostly plug and play without doing too much wiring that you guys recommend? And if so please post pics of them!
Thank you!!
Are you okay with Micro LEDs and not getting a new flasher relay?
I SCOURED the internet looking for lights with the same bolt size as ours so didn't have to file or drill out our stock mounts.. I found ONE seller on ebay that had the right size.
I have a write up on it I will find and link for you but all I did was paint a few washers back and used rubber washers against them for vibration/water.
https://www.ebay.com/itm/3929342159...mp;var=&widget_ver=artemis&media=COPY turn signals that are the same bolt size as ours.
https://www.ebay.com/itm/3324665528...mp;var=&widget_ver=artemis&media=COPY
The wiring adapter you'll need for the rears.
Now with LED the turn signals will "hyper flash" flash faster than the stock because you need a new flasher relay to slow them down to the stock speed. Its like over 100$ and you have to ship it from japan so I dont mind my turn signals flashing faster. If anything I think it catches peoples attention better.
https://r.tapatalk.com/shareLink/to...id=74616&share_type=t&link_source=app
Smaller turn signal/running light choices
Here is the thread on it and I posted photos of how to do all of it in steps. I should have just made it a write up
Awesome thanks I’ll look into those!
m in sc_imp said:
Those have 3 wires and ours have two, how would that work? Not use the one?
Thank you!!
i think i still have the stock lights off my 14
will look and PM if so
Thank you!!
Awesome thanks!
