Dyno results....Re-dyno after reflash?
Waldo_imp Offline
Threads: 5
I just had my bike Dyno'd today. I have a TSR air funnel K&N air filter and a custom slip on exhaust from cone engineering. I had the mods on before the tune. The baseline was 86.39 hp and 68.22 torque and I ended up with 91.19 hp and 71.40 torque. I'm pretty happy with the results. I plan on getting my bike reflas he'd in the future to remove all the de tunes just to have a little more response and a little more on the top end doesn't hurt. My question is would another dyno be worth it after a reflash or will the reflash just improve upon my previous dyno?
01-19-2015, 11:41 PM
HikerToo_imp Offline
Threads: 114
RE: Dyno results....Re-dyno after reflash?
what/how did they adjust or tune in your Dyno?
A dyno just measures things, they have to tune or change something to get more HP based on what the Dyno shows them....
01-20-2015, 01:00 AM
Waldo_imp Offline
Threads: 5
(01-20-2015, 01:00 AM)HikerToo_imp Wrote: what/how did they adjust or tune in your Dyno?
I have a PCV installed.
I mean since the reflash changes how the bike runs would abother dyno run and retune be worth it.
01-20-2015, 01:17 AM
Threads: 114
I believe Don ( Guhls.com) has a couple flash profiles he could put on.
1. My 2013 Dyno tuned onsite w/Staintune( has fuel, timing, limits programmed) fuel map close to PCV
2. Ridem32 had one done with just the limits removed, shipped no bike ( if you are keeping PCV that may be option for you.
3. CIP52 had PCV fuel settings applied, timing tweaked and limits removed. shipped, no bike
4. Metal just had his 2014 ECU flashed, not sur what he ended up with. shipped, no bike.
Have you looked at the PCV fuel ratio they ended up giving you?
Install the DynoJet software on your PC, connect your PCV via USB cable, load/view the map on your PCV to see what fuel changes they made.
01-20-2015, 02:00 AM
grover_imp Offline
Threads: 6
It would be interesting to do a post-flash dyno just to see any changes vs. PCV and ensure the A/F ratios are still in good health...
01-20-2015, 02:04 AM
metallyguitarded_imp Offline
Threads: 62
I just checked the Dynojet website and the map created off of my bike is now listed as an available download (16-040-002 Yoshimura RS-3 slip-on Stock air filter), however, when I click on the link I get a "Page Cannot be Found" message. I suppose it's still in the process of being made available.
HikerToo, I think you're referring to me in #4 and, actually, my ECU is still stock. I took my bike to Dynojet and they installed the PC-V and tuned the bike in order to develop the new map. I'm still considering having my ECU reflashed and, if I do so, need to decide whether to simply remove the limits (#2) and continue running my PC-V or, option #5, see if Don can load the fuel map created at Dynojet directly onto my ECU allowing me to do away with the PC-V. Of course, there's always option #6 - leave well enough alone! Haha. My horsepower and torque numbers are great. The bike rides perfectly.
Waldo, those are great numbers. You need to figure out if the person who would perform your reflash can use the fuel map developed from your tune and download it directly onto your ECU. If so, that would seem to be the best option. It's possible that some minor tweaks could be made to the map after the limits are removed but I don't know that they would be substantial enough to warrant paying for another tune. If you have money to spend and/or connections with a dyno tuner, then why not? Reflash and tune all over. That means, however, that you'll still be running a PC-V after the reflash. It seems that most often, the goal is to do away with a piggy back device and just have the reflashed ECU with the best map available. But I have read of people doing/running both a PC-V and ECU reflash - most often those are track racers looking to squeak out every last drop of HP available.
01-20-2015, 02:30 AM
rboe Offline
Phoenix, AZ
Threads: 64
Likes Received: 6 in 2 posts
Likes Given: 7
A reflash, depending on the map installed (and your goals for a remap) will negate the need for a PC-V. With the ECU now mapped the way you want, the power commander becomes surplus.
01-20-2015, 06:21 AM
Threads: 114
(01-20-2015, 02:30 AM)metallyguitarded_imp Wrote: I just checked the Dynojet website and the map created off of my bike is now listed as an available download (16-040-002 Yoshimura RS-3 slip-on Stock air filter), however, when I click on the link I get a "Page Cannot be Found" message. I suppose it's still in the process of being made available.
Yes, but can you do 113 MPH? :-)
And think what the advanced timing in lower 4/5 gears would do for you.....
01-20-2015, 06:32 AM
Likes Given: 802
Oooh.... wicked ROFL
01-20-2015, 07:40 AM
CB4ME_imp Offline
Threads: 183
Love those HP numbers!
One of these days I'm going to take my bike up to Don. I have Motogear headers, Staintune and TSR air funnel.
01-20-2015, 08:27 AM
  Went back to the dyno today... PowerDubs_imp 20 1,553 11-12-2020, 12:09 AM
  Power Commander 5 and Dyno Tune iamheero_imp 7 620 07-18-2020, 04:14 AM
  ECU from Guhls/Dyno ready HikerToo_imp 120 10,603 04-16-2020, 07:53 AM
  Best Dyno HP numbers? Kawiboy_imp 33 2,586 10-27-2016, 03:22 PM
Last Post: Ulvetanna_imp
  DYNO run today rusty1_imp 3 358 09-27-2016, 11:06 AM
Last Post: Jteakus_imp
  EFI reflash problems? daskraut_imp 1 268 05-15-2016, 05:58 AM
  ECU Reflash CBXBob_imp 5 528 05-11-2015, 01:07 PM
Last Post: CBXBob_imp
  Reflash Tommy's 11_imp 1 242 12-28-2014, 11:38 AM
Last Post: HikerToo_imp
  ECU reflash for tire size change? eakngcobra_imp 1 207 08-09-2014, 11:01 PM
Last Post: CIP57_imp
  I need Dyno maps CIP57_imp 13 948 04-30-2014, 07:48 PM
Last Post: cade_f_imp
