ECU Reflash
CBXBob_imp Offline
Threads: 9
ECU Reflash
Any fuel mileage reports after an ECU Reflash ? Just curious. I know fuel mileage is not the primary concern of most CB1100 owners,
05-08-2015, 12:04 AM
CIP57_imp Offline
Threads: 68
RE: ECU Reflash
(05-08-2015, 12:04 AM)CBXBob_imp Wrote: Any fuel mileage reports after an ECU Reflash ? Just curious. I know fuel mileage is not the primary concern of most CB1100 owners,
fuel mileage will stay about the same.
05-08-2015, 02:50 AM
HikerToo_imp Offline
Threads: 114
RE: ECU Reflash
50 MPG still in general use, very little highway time.
05-08-2015, 02:53 AM
Tommy's 11_imp Offline
Threads: 4
RE: ECU Reflash
About 52 with some pretty aggressive riding in spots.
05-10-2015, 10:56 PM
Motogeezer1949_imp Offline
Threads: 66
RE: ECU Reflash
Unnoticeable if any change.
05-11-2015, 12:49 PM
CBXBob_imp Offline
Threads: 9
RE: ECU Reflash
Um Ok ! mine went from 50 to 42 - 44. Tried with the stock muffler drilled at both ends with long extensions and a 25mm ( i think ) uni-bit with one large hole in each end and 4 or 5 smaller holes along side(sounded a bit louder than stock , and a MSR Italian with a DB killer at both ends that is a little louder than the drilled stock and what I consider is perfect. The price is good but freight just went way up.
05-11-2015, 01:07 PM
  Dyno results....Re-dyno after reflash? Waldo_imp 36 2,705 01-22-2018, 04:51 AM
  EFI reflash problems? daskraut_imp 1 258 05-15-2016, 05:58 AM
  Reflash Tommy's 11_imp 1 241 12-28-2014, 11:38 AM
Last Post: HikerToo_imp
  ECU reflash for tire size change? eakngcobra_imp 1 205 08-09-2014, 11:01 PM
Last Post: CIP57_imp
