I need Dyno maps
CIP57_imp Offline
Threads: 68
I need Dyno maps
Is there anyone who has added a PC5 on there stock or modified bike and has a dyno map?? I'm looking for A/F ratio. If you do please post our PM me. Let me know if the map is stock or modified.
Thanks
Steve
04-17-2014, 01:31 AM
scott will_imp Offline
Threads: 9
RE: I need Dyno maps
i have the pcv w auto tune
replaced stock exhaust with motowerks gp, not cat and little baffling
the map i have had been trimmed about 9 times from the stock power commander map
i have a print screen
04-17-2014, 03:03 AM
Damfino_imp Offline
Threads: 13
04-17-2014, 03:07 AM
lola_imp Offline
Threads: 18
ROFL
(04-17-2014, 01:31 AM)CIP57_imp Wrote: Is there anyone who has added a PC5 on there stock or modified bike and has a dyno map?? I'm looking for A/F ratio. If you do please post our PM me. Let me know if the map is stock or modified.
Thanks
Steve
Steve, I'll post mine on here when I leave work.
04-17-2014, 04:30 AM
CB4ME_imp Offline
Threads: 183
(04-17-2014, 03:03 AM)scott will_imp Wrote: i have the pcv w auto tune
The numbers are percent deviation from stock tuning, right? What does trimming 9 times from stock mean? You changed the PCV map that came with the PCV for the stock bike 9 times?
I'm running the stock map on my PCV and have never pulled in a PC to mine.
04-17-2014, 07:18 AM
Threads: 9
yes these values have been changed from the stock cb1100 map from power commander.
the auto tune has a variance adjustment of plus or minus 20%, you can accept the adjustment it makes after every ride and it changes the map.
this map i had had the bike out 9 times and adjusted everytime.
power commander paperwork says to lower the percent it can adjust once its dialed in and you dont see alot of variance.
i believe the target afm or mixture is 13.47, this number is close(been awhile since i looked at it so im not 100% sure) it shows on the laptop when the laptop its hooked to pcv and the bike is running.
04-17-2014, 07:27 AM
CIP57_imp Offline
Threads: 68
ROFL
I did LMAO
04-17-2014, 07:53 AM
HondaJon_imp Offline
Threads: 53
http://cb1100forum.com/forum/showthread....spreadshee
I also have a few on hand, but our site will not allow me to attach file with a .PVM extension.
You can get the TSR map here:
http://shop.tsrjp.com/item/IS00008N00490.html
Scott, I didn't add your map for two reasons;
I anticipate the "autotune" will do just that every time you ride, so the map is perpetually changing on your bike.
I need a .pvm file to work with. Much time needed to re-type map into excel....
Did you have a new bung welded onto you header? The autotune sensor, if memory recalls, is much larger than the stocker.
04-17-2014, 04:53 PM
Tortuga_imp Offline
Threads: 23
Whilst this was grossly unhelpful, immature and downright inflammatory, I absolutely love it! Clap
04-17-2014, 06:18 PM
Likes Received: 618 in 276 posts
Likes Given: 789
ROFL
04-18-2014, 12:00 AM
  PCV maps for cat delete and K&N filter… SoCal CB1100_imp 2 258 01-03-2022, 11:55 AM
  Went back to the dyno today... PowerDubs_imp 20 1,453 11-12-2020, 12:09 AM
  Power Commander 5 and Dyno Tune iamheero_imp 7 583 07-18-2020, 04:14 AM
  ECU from Guhls/Dyno ready HikerToo_imp 120 9,790 04-16-2020, 07:53 AM
  Dyno results....Re-dyno after reflash? Waldo_imp 36 2,604 01-22-2018, 04:51 AM
  Best Dyno HP numbers? Kawiboy_imp 33 2,400 10-27-2016, 03:22 PM
Last Post: Ulvetanna_imp
  DYNO run today rusty1_imp 3 345 09-27-2016, 11:06 AM
Last Post: Jteakus_imp
  Power commander V maps?? Kawiboy_imp 1 329 01-10-2016, 08:21 AM
Last Post: SUPERCRUZ_imp
  Dyno Results Today 12cb96vfr_imp 15 1,118 02-15-2014, 01:39 PM
Last Post: SanPete_imp
  Wanted to share my map from my Dyno 12cb96vfr_imp 12 677 12-31-2013, 05:41 AM
Last Post: 12cb96vfr_imp
