ECU from Guhls/Dyno ready
HikerToo_imp Offline
Threads: 114
OK, I got the call, my CB is ready.
Will pick up tomorrow (9/13) morning, can report more then.
Don said he got about 6% more HP, I was hoping for more.
He applied fuel mix tweaks = to PCV, timing advances in lower gears, and removed upper speed limit. Don thinks I will be happy with overall performance and mentioned there were gains throughout the RPM range. I assume if anyone calls with a 2013CB, he can flash ECU without bike, and also thinking would work with stock, Staintune and other exhausts( just like the current PCV map, works with most setups that have been tried).
Will be installing lower handlebars tomorrow during the afternoon rain, I am sure that will add another 4% HP!
http://www.guhlmotors.com/
09-12-2014, 02:25 AM
CIP57_imp Offline
Threads: 68
RE: ECU from Guhls/Dyno ready
(09-12-2014, 02:25 AM)HikerToo_imp Wrote: OK, I got the call, my CB is ready.
Sounds good. Don't forget to ask him for the before and after dyno maps and more important the A/F ratio changes.
Edit: Please post the 2 charts.
09-12-2014, 02:39 AM
Threads: 114
Hey CIP, I think he said he just applied the PCV maps for fuel, not sure if he tweaked more from that starting point.
I did ask if it was any different from what he did to yours( the guy from NY's), since it sounded about the same, he said he was able to get more out of this one since he had the bike.......
I also removed the PairValve block before giving it to him, he is aware of that tweak and said I should probably put it back.
09-12-2014, 02:48 AM
Likes Given: 789
6 % ... Does that equate to about 5 HP? Should put you close to 90 hp.
09-12-2014, 03:29 AM
Likes Received: 877 in 480 posts
Likes Given: 1,011
Good one HikerToo. Very generous of you to supply your g̶u̶i̶n̶e̶a̶p̶i̶g̶ er bike to Don.
I'm really keen to hear how it goes.
09-12-2014, 08:01 AM
Threads: 114
Just got back from Guhl's with my newly flashed ECU
unfortunately it was raining or roads were wet most of the way home, 75 minutes away...we're talking twisty roads with fresh Amish wagon horse stuff on them, beautiful country though.
I did not have a chance to go over 6K RPM's
One thing I can say, is it still runs good, no oddities were added from the flash, smooth and responsive.
It did seem to pull better from 3 to 4K RPM's
When I got close to home, I was able to do one short run of close to redline shifts and it seemed to have extra pull, although I let off around 95 MPH....
so far, so good.
09-13-2014, 12:47 AM
Lord Popgun Offline
El Supremo RLET Force
Virginia
Likes Given: 142
Any dyno run charts you can show us?
09-13-2014, 01:07 AM
CIP57_imp Offline
Threads: 68
There is no dramatic change with the flash. I had a realized gain of about .2 sec's 0-100. You should notice a better throttle response at 1/4 throttle especially in the lower gears and no limiter is a big plus. Your 60-80 times at full throttle in 5th should be better and smoother.
09-13-2014, 01:11 AM
Threads: 114
(09-13-2014, 01:07 AM)Lord Popgun_imp Wrote: Any dyno run charts you can show us?
Yes, I have them on paper, will try to post electronic copy in next day or so, they were not very impressive, maybe
before = 79
after = 83
but certainly feels snappier, I like the difference.
09-13-2014, 02:18 AM
HondaJon_imp Offline
Threads: 53
Hiker,
Are you still running the stock header or one with a CAT?
09-13-2014, 04:01 AM
  Went back to the dyno today... PowerDubs_imp 20 1,462 11-12-2020, 12:09 AM
  Power Commander 5 and Dyno Tune iamheero_imp 7 583 07-18-2020, 04:14 AM
  Dyno results....Re-dyno after reflash? Waldo_imp 36 2,606 01-22-2018, 04:51 AM
  Best Dyno HP numbers? Kawiboy_imp 33 2,417 10-27-2016, 03:22 PM
Last Post: Ulvetanna_imp
  DYNO run today rusty1_imp 3 348 09-27-2016, 11:06 AM
Last Post: Jteakus_imp
  Plush Saddle: Getting Ready for a Ride to Bland Nemo_imp 12 867 03-26-2016, 05:21 AM
Last Post: Nemo_imp
  CB prepped and ready for duty soggybottom_imp 28 1,868 02-17-2015, 02:12 AM
Last Post: ClassicVW_imp
  ECU READY TO SHIP CIP57_imp 76 5,285 06-29-2014, 01:11 PM
  I need Dyno maps CIP57_imp 13 879 04-30-2014, 07:48 PM
Last Post: cade_f_imp
  Parts almost ready Romo1969_imp 2 237 04-25-2014, 09:01 PM
