Flasher - Buzzer installation on a 2017 CB1100
17-CB-002 Offline
Threads: 45
Self Cancel Turn signal or noise buzzer installation for a 2017 CB1100.
Just curious, I am in process of adding a buzzer unit to my flasher unit. I was wondering whether someone had ever done the modification.
Reason being, got a near miss on the weekend, forgot to cancel the signal flasher after a turn, then at the next intersection a truck pulled in front of me thinking that I was turning due to the turn signal left on.
I studied the schematic and concluded that the turn flasher relay is different from conventional.
1st, it is electronic therefore noiseless.
2nd, not a regular type - will attach a schematic soon.
My idea is to install a noise buzzer which should buzz at the same pace to the flasher therefore reminding me that the turn signal is left on.
Any idea before I start my modification?
Note; same flasher unit used on 2013 models.
06-19-2018, 02:35 AM
Likes Given: 1,020
RE: Flasher - Buzzer installation on a 2017 CB1100
Alain, this thread offers other possible solutions to your problem. http://cb1100forum.com/forum/showthread.php?tid=12774
I’m very pleased to hear it was a miss.
06-19-2018, 08:27 AM
2017EX_imp Offline
Threads: 45
Alain, I started the thread Cormanus gave you the link to. Although hard wired buzzers/beeprs are available for about $12 on EBay, I questioned whether or not it could actually be heard while wearing a helmet with ear plugs, plus all other outside noise on the road. My conclusion was, and still is, a wireless buzzer or beeper mounted inside the helmet. If I knew how to build one, it would already be inside my helmet, because no one makes it at this point.. The link for the EBay buzzer in my original post is no longer good, so here is a current link for the same buzzer: https://www.ebay.com/itm/Audible-motorcy...SwaG9XJS1t
06-19-2018, 08:47 AM
peterbaron Offline
Likes Received: 594 in 325 posts
Likes Given: 1,003
(06-19-2018, 08:47 AM)2017EX_imp Wrote: Alain, I started the thread Cormanus gave you the link to. Although hard wired buzzers/beeprs are available for about $12 on EBay, I questioned whether or not it could actually be heard while wearing a helmet with ear plugs, plus all other outside noise on the road. My conclusion was, and still is, a wireless buzzer or beeper mounted inside the helmet. If I knew how to build one, it would already be inside my helmet, because no one makes it at this point.. The link for the EBay buzzer in my original post is no longer good, so here is a current link for the same buzzer: https://www.ebay.com/itm/Audible-motorcy...SwaG9XJS1t
I like these....specially for 2014 = smaller indicators, unlike 2013 had = larger
Thumbs Up
pb
06-20-2018, 08:48 AM
SportsterDoc Offline
New Mexico
Threads: 33
Likes Received: 43 in 22 posts
Likes Given: 6
At the end of a vacation to British Columbia and the Olympic peninsula, so schematics are not available to me right now. However, the easiest would be to tie into the rear turn signals with one beeper each or a single unit with diodes.
The fronts have variable voltage to dimly illuminate a 2.1 amp single filament bulb for running lights and full voltage for turns.
06-20-2018, 08:54 AM
17-CB-002 Offline
Threads: 45
Thanks Peter, We nearly met in July last year during a ride in the Cambridge area.
You came late and missed everyone as we departed on time.
Thanks for the input.
Will keep you posted if it works.
06-20-2018, 01:09 PM
Chuckk_imp Offline
Threads: 19
(06-19-2018, 02:35 AM)Alain Lee_imp Wrote: Self Cancel Turn signal or noise buzzer installation for a 2017 CB1100.
I have installed this one from eBay.. https://www.ebay.com/itm/Audible-motorcy...SwaG9XJS1t
it is cheap and works great !! .. I had to mount the beeper to my left handlebar, to be able to hear it well.. I also pointed it towards me.. the sound seems to be focused and directional.. the best part however, is when you apply the brake, it stops the loud beeping.. say waiting at a light.. then when you release the brakes and take off, the beeping starts up again.. then just do what it is reminding you to do and cancel the directional.. perfect !! ..
01-15-2019, 08:16 AM
Interesting find Chuckk.
01-15-2019, 08:21 AM
Chuckk_imp Offline
Threads: 19
by the way, I have a 2017 CB1100.. but this beeper should work on many 12v systems.. you just have to attach 3 wires.. break into one wire leading to the left directional and one wire leading to right directional.. the easiest place, I found, was under the seat.. using the rear directionals.. (you could go into the headlight bucket as an option) the third wire is attached to the positive side of the brake light wires.. when the brake light is not on, that hot wire will act as a ground.. when the brake light is on, it no longer is a ground.. the beeper has then lost it's ground and will stop beeping..release the brake and the ground is restored to the beeper.. one more tip.. break into the directional wires as far forward as you can.. the wires supplied on the beeper are just long enough to reach to the handlebars..
01-15-2019, 08:48 AM
Hey Chuckk: How does it sound? Like a buzz or more like a beep? Can you attach a short MP3 audio clip? (if supported by Forum site)
01-15-2019, 10:10 AM
  Tall seat for 2017+ CB1100 Run Away_imp 23 1,880 09-18-2024, 02:51 AM
Last Post: Darrell_imp
  Honda Top Box Installation Duffy_imp 15 1,342 06-23-2023, 02:21 AM
  Installation of a Quad Lock Wireless Charger [No Cut Mod] LayerCake_imp 5 671 06-17-2022, 07:44 AM
Last Post: LayerCake_imp
  Installation of a Smart Turn System [No Cut Mod] LayerCake_imp 20 1,918 06-15-2022, 01:28 AM
Last Post: KiowaEagle_imp
  LED Flasher Relay hardylt_imp 79 5,903 06-10-2021, 04:31 AM
Last Post: hardylt_imp
  Download Installation Instructions for Honda Accessories CB4ME_imp 10 763 02-28-2021, 04:55 PM
Last Post: Griff_imp
  Flasher Unit built to a price ? 17-CB-002 15 1,417 03-27-2019, 02:12 AM
  Grip Puppy Installation 2017EX_imp 10 976 06-19-2018, 11:53 AM
Last Post: jdinaz_imp
  Considering a WhiteHouse Kit / SoCal Installation? joeldelman_imp 15 1,041 10-02-2017, 10:53 PM
  Road comet fairing 2017- installation question pittycheria_imp 18 1,494 08-29-2017, 11:08 AM
Last Post: Jeya_imp
