Grip Puppy Installation
2017EX_imp Offline
Threads: 45
The stock grips on my CB are a bit too small in diameter for me, and result in my hands cramping in a short amount of time. I have been considering Grip Puppies for a while, and have watched the Youtube installation videos, using both the soapy water and air compressor techniques. Using the air compressor looks much easier and faster than the soapy water method to me. Has anyone here used the air compressor method, and if so, how well did it work? I also wondered if they get wet, do they turn into soggy sponges?
06-03-2018, 12:39 AM
memphismike_imp Offline
Threads: 24
RE: Grip Puppy Installation
(06-03-2018, 12:39 AM)2017EX_imp Wrote: The stock grips on my CB are a bit too small in diameter for me, and result in my hands cramping in a short amount of time. I have been considering Grip Puppies for a while, and have watched the Youtube installation videos, using both the soapy water and air compressor techniques. Using the air compressor looks much easier and faster than the soapy water method to me. Has anyone here used the air compressor method, and if so, how well did it work? I also wondered if they get wet, do they turn into soggy sponges?
I have them as well...heck you may seen my "install" vid. they get a little soggy but will dry out with no problem at all. they were just the right amount of extra beef i needed in the hands
06-03-2018, 12:48 AM
2017EX_imp Offline
Threads: 45
Mike, Yes I saw your install video...have you seen the air compressor install vid on youtube? Compressor install looked mush easier and faster, so I was looking for feedback on that method. BTW, thanks for the tip on Earpeace plugs. I got a pair and like em. Before your tip I was going to try No Noise ( $30 plus shipping, only 1 filter set, and only 1 set of plugs without the 1 extra for spare ).
06-03-2018, 01:47 AM
KiowaEagle_imp Offline
Threads: 36
I haven’t seen the air compressor video but I will attest the soapy water method was quick and easy. I let the bike sit in the sun for an hour afterward and they were dry enough to ride. Didn’t need much soap either so I’m not worried about when they get wet again.
06-03-2018, 03:16 AM
itstuantran_imp Offline
Threads: 7
(06-03-2018, 03:16 AM)KiowaEagle_imp Wrote: I haven’t seen the air compressor video but I will attest the soapy water method was quick and easy. I let the bike sit in the sun for an hour afterward and they were dry enough to ride. Didn’t need much soap either so I’m not worried about when they get wet again.
Here is the air compressor installation vid Big Grin
https://www.youtube.com/watch?v=lLEtqRZCc4E
06-04-2018, 04:19 PM
max Offline
Threads: 39
Likes Received: 15 in 8 posts
"Black magic", thanksTuantran
06-04-2018, 07:17 PM
Threads: 36
Thanks! I plan to put them on my ZR750 so I'll try that method then.
06-04-2018, 10:22 PM
Calcb_imp Offline
Threads: 2
I put these on all the bikes I own. Spray some hairspray inside the grip puppies and on the existing grips and they will slide right on and dry. Easy.
06-06-2018, 04:19 AM
Roper_imp Offline
Threads: 32
I used the same method I've always used when installing handlebar grips on bicycles: A liberal amount of rubbing alcohol on the inside of the grip then push and twist them on. It required a bit of muscle, and you only get about 30 seconds before the alcohol dries too much. But they went on perfectly. No soap residue, so there's no concern of them slipping. Ready to ride in less than five minutes.
06-19-2018, 03:54 AM
Stichill Offline
Kentucky, USA
Threads: 93
Likes Received: 9 in 4 posts
Likes Given: 6
Another method is to use hairspray inside them. It lets you get the grips on easily but dries overnight and acts like a mild glue so they don't slip.
06-19-2018, 11:03 AM
  Honda Top Box Installation Duffy_imp 15 1,324 06-23-2023, 02:21 AM
  Installation of a Quad Lock Wireless Charger [No Cut Mod] LayerCake_imp 5 643 06-17-2022, 07:44 AM
Last Post: LayerCake_imp
  Installation of a Smart Turn System [No Cut Mod] LayerCake_imp 20 1,820 06-15-2022, 01:28 AM
Last Post: KiowaEagle_imp
   Handle Grip Options Yata-Garasu_imp 24 1,765 10-26-2021, 11:28 AM
Last Post: rboe
  Download Installation Instructions for Honda Accessories CB4ME_imp 10 723 02-28-2021, 04:55 PM
Last Post: Griff_imp
  Trip Machine red leather grip wraps treedoc_imp 20 1,440 02-09-2021, 04:02 AM
  HEATED GRIP HONDA ORIGINAL - CB1100 ex 2015 Alfgaxatico_imp 9 750 11-21-2020, 09:45 AM
Last Post: Alfgaxatico_imp
  I need Grip Recommendations cbolling_imp 11 941 11-02-2020, 04:24 AM
  Grip options Cqrlm911_imp 9 832 07-04-2019, 02:29 AM
  Flasher - Buzzer installation on a 2017 CB1100 17-CB-002 12 924 01-15-2019, 12:26 PM
