Installation of a Quad Lock Wireless Charger [No Cut Mod]
LayerCake_imp Offline
Threads: 5
Another thread another few wires to cram into the headlight.
This time to add a mount and wireless charging for my phone in the form of a quad lock.
Here are all the components, instead of the official quad lock power supply which senses the battery and does fancy stuff I used a dumb [url=https://www.amazon.de/gp/product/B09B7XZYJQ]12V to 5V 3A USB supply from Amazon.
[Image: a3c4542702530aa9a1ffb9e4e5779bc2.jpg]
[Image: 09dab79606f9cdd988b4d5087797614d.jpg]
As if someone was planning for this there is a nice convenient connector in the headlight that supplies power only when the ignition is on.
It uses the SUMITOMO HM 090 connectors which can be found [url=https://aliexpress.com/item/4000883671545.html]here on AliExpress.
[Image: 9689b6740aa9eb02cc1c96b6d1b11a25.jpg]
I used some heat shrink to cover the USB connection mostly just to keep it in place through all the vibrations.
[Image: 26fba640d7e1fb34b34109dfc09674be.jpg]
And here's the final product works pretty well with the phone case.
The only thing I don't like is that you basically have to decide if you want to mount the phone horizontal or vertical as removing the phone is only easy if the longer sides of the puck can be grabbed around the phone.
This could have been solved if the puck had more of a plus/cross shape not just one longer orientation.
[Image: c724141b561570a69cbca58cbc6b6b1c.jpg]
[Image: 1de13337c0e45a21c5c49193bc3f5e75.jpg]
06-14-2022, 04:55 AM
RE: Installation of a Quad Lock Wireless Charger [No Cut Mod]
Nice wireless charger mount LayerCake.
Is the mount relatively easy to steal?
06-14-2022, 07:10 AM
Threads: 5
(06-14-2022, 07:10 AM)GoldOxide_imp Wrote: Nice wireless charger mount LayerCake.
Thank you.
If you carry the correct size allen key yeah easy enough to steal.
No idea how you'd prevent that.
06-14-2022, 07:15 AM
Thank you.
Thank you.
The RAM X-Grip has the same problem, but they probably less desirable to lift off the bike than your mount. They still cost some coin to replace, so RAM offers a key lock for the clamp down nut. Alternatively, there are "free spinning" nuts available that requires a special driver to remove, but it does prevent the easy theft.
06-14-2022, 10:48 AM
Threads: 5
Figured I should at least show the case mounted on it even if I need the phone to take the pictures.
[Image: 3574ac0ea3f47fcc9b83aeabfb5f4e7c.jpg]
06-17-2022, 03:45 AM
Threads: 5
Thank you.
Thank you.
I might add some snake eye screws. Or just 3D print a plug for the screw and glue it in the hex hole.
06-17-2022, 07:44 AM
  Honda U Lock guitardo_imp 12 948 04-09-2026, 09:36 AM
  Quad Lock handlebar vs clutch perch and bar-end mirrors Uncle Sixer 1 329 01-04-2026, 01:26 PM
  Phone or Sat Nav? What mount ? Quad lock or...... Davidjill_imp 18 1,403 07-28-2024, 08:49 AM
Last Post: SportsterDoc
  Honda Top Box Installation Duffy_imp 15 1,339 06-23-2023, 02:21 AM
   Quad lock stem mount Dunn2020_imp 5 559 06-07-2023, 12:36 AM
  CB1100 Lock Lord Popgun 100 7,139 12-24-2022, 11:15 AM
Last Post: olafurarason_imp
  Installation of a Smart Turn System [No Cut Mod] LayerCake_imp 20 1,873 06-15-2022, 01:28 AM
Last Post: KiowaEagle_imp
  U-Lock Rubber Band LakeWylieJoe_imp 39 2,507 05-02-2021, 04:00 AM
Last Post: LakeWylieJoe_imp
  Download Installation Instructions for Honda Accessories CB4ME_imp 10 751 02-28-2021, 04:55 PM
Last Post: Griff_imp
  QUAD LOCK IPHONE SYSTEM Alfgaxatico_imp 33 1,900 01-25-2021, 08:39 AM
