Flasher Unit built to a price ?
17-CB-002 Offline
Threads: 45
Just being curious & learning the in/out of my 2017 EX, I removed the front flasher lens and noticed that HONDA (Stanley) did not use a reflector to project the flasher light.
I did some experiment using a GU10 projector bulb reflector,however, the result was inconclusive (failed).
I then used a reflective silver ducting tape behind the bulb and around the inner housing surface.
You can be the judge on which side projects more light - Left or Right side when facing the bike?
I wil later post which flasher side I modified.
03-25-2019, 02:33 PM
Csory_imp Offline
Threads: 2
RE: Flasher Unit built to a price ?
Left (as seen from driving position) looks a lot brighter to me.
03-25-2019, 04:08 PM
tommymck Offline
Florida/Maryland
Threads: 34
Likes Given: 9
The thing with flashers is that you don't want to focus the light. This is so that it is visible to others from as wide an angle as possible.
If you use a reflector to focus the light on flashers, by definition you are making them less visible to the side. And this is more of an issue for the front flashers because they are of most use to oncoming drivers who will be off to the side of you.
03-25-2019, 04:47 PM
peterbaron Online
Likes Given: 996
(03-25-2019, 02:33 PM)Alain Lee_imp Wrote: Just being curious & learning the in/out of my 2017 EX, I removed the front flasher lens and noticed that HONDA (Stanley) did not use a reflector to project the flasher light.
Never too late to learn = thanks for sharing, will dig in mine soon
AL, can you post pic of your '79 CBX, please
Smile
03-25-2019, 08:24 PM
(03-25-2019, 04:47 PM)tommymck_imp Wrote: The thing with flashers is that you don't want to focus the light. This is so that it is visible to others from as wide an angle as possible.
Come to think of it Alain, I recall your observation. Interesting though. tommymck's logic makes sense in regards to the intent to warn others of turn intent. If you look at the signal lens cap, it extends out from the signal stock to help in light dispersion.
03-25-2019, 09:42 PM
17-CB-002 Offline
Threads: 45
Come to think of it Alain, I recall your observation. Interesting though. tommymck's logic makes sense in regards to the intent to warn others of turn intent. If you look at the signal lens cap, it extends out from the signal stock to help in light dispersion. Yes, your observation is correct.
The modification helps spread the light better to the side even though the lumens remains the same.
Yes, the modification is on the left side (when viewed sitting on the bike).
Smile
Smile
Sorry Peter, the 79 Red CBX is at the garage for engine repair.
I had a hydraulic lock on cylinder #1 last spring, the fuel tap had a slow leak during the winter storage and fill out the cylinder.Angry
03-26-2019, 01:13 AM
peterbaron Online
Likes Given: 996
Smile
Smile
Smile
Smile
OK, it was common issue with it, I guess. Thanks for feedback and good luck with your repair Thumbs Up
03-26-2019, 02:45 AM
The signal design light dispersion level likely met [then current international] specifications for safety and hence, Honda may had no reason to expend extra cost optimizing the routing/deflection of the light.
03-26-2019, 02:58 AM
tommymck Offline
Florida/Maryland
Threads: 34
Likes Given: 9
I think that what Alain is saying is that the inside of the back and sides of the housing is black or something. In that case, adding reflective material would increase the output forward. So long as the housing isn't a parabola with the bulb at the focus, it wouldn't focus either. Not sure how this would "spread" the light out though, and since it's going through a diffuser anyway, I wouldn't think it'd be necessary. In any case, if the goal is to increase the output of the signals, sounds good to me.
03-26-2019, 03:30 AM
Houtman_imp Offline
Threads: 115
Did your CBX bend a rod ?
03-26-2019, 05:07 AM
  LED Flasher Relay hardylt_imp 79 5,624 06-10-2021, 04:31 AM
Last Post: hardylt_imp
  NEW PROTECTION AT GOOD PRICE 110 € Alfgaxatico_imp 0 229 12-03-2020, 06:18 AM
Last Post: Alfgaxatico_imp
  Flasher - Buzzer installation on a 2017 CB1100 17-CB-002 12 924 01-15-2019, 12:26 PM
  Rear brake light flasher. walrusz06_imp 15 1,106 01-18-2017, 08:56 PM
Last Post: Rocky_imp
  She's a flasher PowerDubs_imp 12 932 09-06-2016, 05:09 AM
  Brake light modulator/flasher in a bulb dBuster_imp 7 673 06-24-2014, 03:20 AM
Last Post: Ridem32_imp
  Has anybody installed flasher relay for led signals? Romo1969_imp 7 530 04-18-2014, 11:12 PM
Last Post: Romo1969_imp
  Brake Flasher Deanohh_imp 7 611 11-06-2013, 10:09 AM
Last Post: rjk555_imp
  Cheapest price for Staintune? HikerToo_imp 13 834 08-17-2013, 02:30 PM
Last Post: BuffaloBill_imp
