Handlebar riser
Ale72_imp Offline
Threads: 4
Handlebar riser
Hello everyone, i would like to install 20 cm handlebar risers on my cb 1.100 ex 2017, can you confirm that there are no problems with the cables? if someone has already done so, can you give me your impressions?
thank you.
12-27-2019, 01:45 AM
Ben70_imp Offline
Threads: 23
RE: Handlebar riser
If I am correct that 20cm is a bit over 7 in, then yes, you would have a problem. 1 inch is no problem, 2 is questionable.
Ben
12-27-2019, 02:18 AM
Houtman_imp Offline
Threads: 115
RE: Handlebar riser
(12-27-2019, 01:45 AM)Ale72_imp Wrote: Hello everyone, i would like to install 20 cm handlebar risers on my cb 1.100 ex 2017, can you confirm that there are no problems with the cables? if someone has already done so, can you give me your impressions?
thank you.
Did you mean 20 mm ?
12-27-2019, 07:48 AM
Ale72_imp Offline
Threads: 4
RE: Handlebar riser
thank you.
Did you mean 20 mm ? Yes 20 mm not 20 cm sorry
12-27-2019, 07:50 AM
lash_imp Offline
Threads: 8
RE: Handlebar riser
I used 2 inch/50mm Rox Risers on mine and they worked with the stock cables..
12-27-2019, 08:26 AM
peterbaron Offline
Likes Given: 996
RE: Handlebar riser
Hello Lash, how is your CB stable, any new arrivals???
12-27-2019, 08:32 AM
jimgl3_imp Offline
Threads: 27
RE: Handlebar riser
mine are 1 and a half or 2 inch, can't recall for sure. ended up freeing the lines from the bolt that keeps the brake lines fastened in place (where the lines make a "Y") to provide some stress relief on the lines. haven't had any issues with it this way.
12-27-2019, 09:31 AM
lash_imp Offline
Threads: 8
RE: Handlebar riser
Peter, last winters project, another 69 rescue bike.. still have all the others..Big Grin
12-27-2019, 12:21 PM
RE: Handlebar riser
Jeez Lash - that is ultra sweet! Worship
Where were you during BigSheep's Southern Ontario Rally this year? It would have been awesome to worship this thing of beauty.
12-27-2019, 12:28 PM
peterbaron Offline
Likes Given: 996
RE: Handlebar riser
(12-27-2019, 12:21 PM)lash_imp Wrote: Peter, last winters project, another 69 rescue bike.. still have all the others..Big Grin
Jeeeeeez... MUST visit you again in 2020 seasonBig Grin
So now, you have 750cc full set of colours and models, correct???
Any CBX or old GW???
Banana
12-27-2019, 12:30 PM
  USB ON HANDLEBAR - connection at battery direct . Alfgaxatico_imp 38 2,686 05-17-2026, 10:20 PM
  Quad Lock handlebar vs clutch perch and bar-end mirrors Uncle Sixer 1 315 01-04-2026, 01:26 PM
  Handlebar control symmetry Uncle Sixer 17 1,643 08-07-2025, 05:24 AM
  Handlebar Risers?? bubblerboy64_imp 16 1,449 07-16-2022, 06:04 AM
Last Post: calipo223_imp
  What to do with the handlebar mounts when converting to clip-on controls? misterprofessionality 7 741 04-08-2022, 03:41 AM
  CB 1100 EX Handlebar original or other? MALACAY_imp 4 534 04-03-2022, 01:00 AM
  Handlebar from 919 motorider6_imp 10 893 05-27-2021, 12:47 PM
Last Post: Stichill
  CRF1000 handlebar mspaansnl_imp 0 231 05-25-2021, 04:57 AM
Last Post: mspaansnl_imp
  HANDLEBAR RISERS - is really necessary??? Alfgaxatico_imp 19 1,378 12-16-2020, 10:40 PM
  Early 80’s handlebar clamp PowerDubs_imp 33 2,037 10-10-2020, 02:36 AM
Last Post: Gordo_imp
