Spark Plug Question
Just curious. There is a little piece of plastic at the base of the spark plugs. Why? And, do they have to be removed to replace the spark plugs? Maybe such is just new to me.
(06-16-2013, 12:07 PM)AZrider_imp Wrote: Just curious. There is a little piece of plastic at the base of the spark plugs. Why? And, do they have to be removed to replace the spark plugs? Maybe such is just new to me.
You are talking about the gray plastic collar at the base of the black connector? That is part of the connector and comes off with it.
If you are talking about the finned pieces bolted to the head they are there to direct cooling air around the spark plugs for epa purposes.
I was talking about the piece bolted down. Does that have to be removed to remove the spark plug? Surely not. Just never seen such before. Just curious as I said.
I dont think they need to be removed when changing plugs, although I dont have a shop manual to verify that. Ive never seen anything like them before either, but I do know getting this air/ oil cooled bike to pass epa regs in Europe/U.S. posed some interesting issues for Honda which they overcame using several ingenious tricks.
(06-17-2013, 04:02 AM)AZrider_imp Wrote: I was talking about the piece bolted down. Does that have to be removed to remove the spark plug? Surely not. Just never seen such before. Just curious as I said.
The fins are not removed. The plug wrench fits inside those. It's a 14mm socket.
Thanks for the information.
  Booster Plug on an RS TheLegend 6 417 04-22-2026, 06:31 AM
Last Post: TheLegend
  spark plugs after 70.000 Km DAC 16 1,366 12-23-2025, 10:15 AM
  What is this plug? MagnaRider 7 613 02-13-2025, 03:39 AM
Last Post: MagnaRider
  NGK spark plug options Jonnyteabag_imp 1 329 11-10-2024, 02:05 AM
Last Post: Davidjill_imp
  'Factory' high performance spark plugs PowerDubs_imp 17 1,328 10-23-2024, 02:50 PM
Last Post: rtmoto1
  Spark plug socket. Jgarciajr40_imp 5 515 09-11-2023, 10:40 PM
Last Post: Jgarciajr40_imp
  spark plugs NGK LMAR8A-9S louied_imp 1 308 06-27-2023, 01:19 PM
  spark plug caps alexzanutto_imp 3 372 01-29-2023, 06:21 AM
Last Post: artashline_imp
  spark plug help, please !! The Gecko_imp 10 676 10-08-2022, 12:22 PM
  Spark Plugs HondaJon_imp 105 6,276 03-19-2022, 08:53 AM
