removing rear wheel on CB1100NA (RS) Care needed
Hi I've just gone through the process of pulling and refitting the rear wheel on my CB11RS for the purpose of fitting a larger rear sprocket (that didnt fit, but thats a different story). I read the owner manual and the process seemed pretty straight forward as follows:-
Place on centre stand
undo axle nut
Set chain adjusters to min and push rear wheel fully forward
lift chain off sprocket
pull axle and remove caliper bracket as a unit.
It all works well until trying to remove the caliper bracket as a unit as there is little clearance with the 17" rear wheel. I ended up pulling the caliper off the bracket (along with the abs cable ) to just leave the caliper mount without anything attached. This allows the wheel to be easily removed and also eases refitting though I'd locate a suitable shim to place under the rear wheel when fitting to help align the axle wheel bearings/swingarm. Its a bit of a heavy combo trying to lift the wheel making sure all the bits are aligned and push the axle in. Then you can re-fit the caliper abs cable and brackets back onto the caliper bracket.
As mentioned I had intended to fit a larger rear sprocket but I ordered incorrectly and ended up with a 6 bolt sprocket not the 5 bolt one fitted to the CB11 :/.
Upside is i found that my rear axle was fitted dry with no grease on the shaft so I got to sort that out before it became an issue and seized into the wheel.
Thanks for the tips. Shold come in handy for RS owners. Too bad you dodn't notice the hole discrepancy before you pulled the wheel assy, but then you wouldn't have discovered the dry axle. I don't think the factory slathers on the grease like we tend to do, you know where it squishes out when the axle is slid in lol
  Front wheel bearing noise? MagnaRider 20 1,737 03-31-2026, 08:20 AM
  This is why wheel bearings are failing 1973cb750 3 353 02-05-2026, 08:11 AM
Last Post: 1973cb750
  CB11OO EX wheel rims sprint 6 654 02-26-2025, 06:16 AM
  2014 rear wheel knocking noise dunebuggy_imp 7 952 08-05-2024, 03:33 AM
Last Post: Yata-Garasu_imp
  Parts needed Midwestbiker_imp 2 311 02-26-2024, 10:34 PM
  Wheel sensors The Gecko_imp 48 3,917 07-27-2023, 03:51 AM
Last Post: The Gecko_imp
  removing rear turn signal modmaster_imp 12 1,010 04-20-2023, 10:17 AM
  2013 replacement wheel Randy B 8 783 11-13-2022, 10:32 AM
Last Post: Randy B
  ABS - help needed The Gecko_imp 19 1,349 11-03-2022, 03:12 AM
Last Post: max
  wheel imbalance j3gq_imp 7 639 07-03-2022, 09:35 AM
