When your oil filter wrenches won't work?!?
You know when you tried all of your old oil filter wrenches from the strap type to the cap types and none will get a decent grip on the small Honda oil filter?
You're too lazy to drive to the auto parts store so you scour your tool options. The last resort plumbers pipe wrench wouldn't fit because of the headers. Didn't want to go total cave man and poke a big screwdriver through the filter can. What to do?
Then I remembered my woodworkers-oil-filter-wrench:
Crude? Yes. Simple? Yes. Fits around the headers and oil line? Yes. I have a bunch of different sized C-clamps inherited from my father who was a woodworker.
That factory filter is really TIGHT but the C-clamp could make enough of a dent to get a good enough grip to loosen the filter, then I could just unscrew by hand.
Here in Honolulu the city approved way to get rid of your engine oil is to drain it into that absorbent filled plastic bag inside of a cardboard box. Wire tie, tape up the box and put in the city provide trash bin where they take it to the trash-to-power incinerator.
Another idea for keeping your garage floor clean from the inevitable drips during an oil change or chain lube is to tape a puppy pee pad onto some cardboard and position that under your bike. Puppy pee pad should be good for several oil changes unless you really mess up. Yeah, you parents of young ones could use a disposable diaper instead. Or you oldsters could use Depends.
Aloha,
Huladog
That's a great idea. I wouldn't have expected a C clamp would grip tight enough to remove a stuck filter, but obviously I was wrong.
Our city has a waste to power plant as well. I went on a field trip with my sons school and was very impressed. They burn everything that comes in, and claim their emissions are below a standard oil fired plant. They recover metal from the ashes and the landfill they have that was supposed to close a decade ago will stay open for at least another 20 years because only ashes are going into it now. And, as you point out, waste oil can now be safely diposed of in the trash.
(07-22-2013, 09:48 PM)The Spaceman_imp Wrote: That's a great idea. I wouldn't have expected a C clamp would grip tight enough to remove a stuck filter, but obviously I was wrong.
Yea, me either. I would probably flip it around the other way though with the C part on the bottom for turning counter clockwise.
My "oil filter wrench" is a big pair of Channel Locks. Works every time!
Quote:I wouldn't have expected a C clamp would grip tight enough to remove a stuck filter,
I tried it the other way but the clamp ran into clearance problems with the header and oil line. The other way makes more sense, but the way I used it provided the clearance needed.
Yep, if I had a big-@ss Channel Lock I would use that for sure!
To save me grief the next time I went ahead and ordered the Honda oil filter cap wrench thing with the filter.
Aloha,
Huladog
"the Honda oil filter cap wrench thing with the filter."
Has anybody tried that on our bikes? I cut down a two-size cap wrench so only the lower half was left (that being the half that fit our filter, of course). Anyway, it didn't look any bigger than the one Honda sells, but with a ratchet handle it wouldn't clear the headers. I'm wondering why the Honda tool would be any better.
Allow me to clarify. It's this Honda OEM part number 15010-mce-h51 that vfrpaul98 posted about in this topic: http://www.cb1100forum.com/forum/showthread.php?tid=214
Sure you can find a similar tool at the local auto parts store if you remember to bring along a clean unused Honda filter to test fit.
I was lazy so I ordered it on eBay from a Honda dealer and I'll mark it "Honda" so I'll know what its for when it gets lost in my tool box.
Aloha,
Huladog
This one has yet to fail me on any of the past and current Honda bikes: http://wingstuff.com/products/30448-3-in...m_search=1
(07-23-2013, 10:04 PM)ron1100_imp Wrote: This one has yet to fail me on any of the past and current Honda bikes: http://wingstuff.com/products/30448-3-in...m_search=1
That is a cool-tool for sure. Wished I had known about that one before I ordered the Honda OEM tool!
As designed it would make the simple oil change even simpler. Heck, I'm going to order one anyway.
Aloha,
Huladog
Since the CBR1000RR and the CB1100 use the same oil filter, I already had the Honda wrench. Dog pee pads? How much oil do you spill? Usually, I don't spill any.
  Oil Filter dave 12 550 07-26-2026, 02:33 PM
  Bead method of balancing tires, does it work? MagnaRider 3 422 01-06-2025, 03:03 AM
Last Post: MagnaRider
  Pod Air Filter Traumend_imp 15 1,482 03-06-2024, 08:42 AM
  K&N air filter fitment question nikolus_imp 28 3,508 05-20-2023, 09:26 AM
Last Post: Klamathonian_imp
  Fuel filter replacement Mafd2_imp 36 2,892 02-11-2023, 01:54 AM
  Oil filter won’t come off Jgarciajr40_imp 20 1,553 01-01-2023, 09:38 AM
   Oil Filter Options Yata-Garasu_imp 78 7,469 09-28-2022, 08:03 AM
Last Post: Yata-Garasu_imp
  Air filter options - W/ Part #'s PowerDubs_imp 10 909 09-21-2022, 04:02 AM
  Video: oil and filter change Scotty_imp 15 1,204 12-05-2021, 02:43 AM
  Air Filter Change Interval? dave 25 1,921 11-09-2021, 02:18 AM
Last Post: SportsterDoc
