Taillight/Signal Connector Types
Wondering if anyone here knows what type of connector the two turn signal (2p) and the taillight (3p) connectors under the seat are (i.e. model numbers/model types/whatever) so I can order them to do a nice install for the lights for my top box.
I'd rather not just tap the wires because that's ugly; I'd prefer to fab up a harness using the OEM connectors so I can take it apart later if want to without any remnant.
Posi-taps?
(11-08-2013, 06:15 AM)ron1100_imp Wrote: Posi-taps?
Need to shrink wrap the wire after you take them off or else you leave a hole in the wire. I'll figure out the part number one of these days. Hopefully soon.
OK, I found them. They're .050" two and three pin connectors. They are orange and blue for our bikes (and most Hondas) indicating left and right (not sure which is which, yet). You can get them here, should anyone else need to connect anything up to their rear (I believe front, as well) turn signals/brake light (the signals are the two pin connectors, and the brake light is the three): http://easternbeaver.com/Main/Elec__Prod...tors.html.
Good to know. Thank you.
  Rear indicator (Turn signal) relocation bracket 2013 model AndyBeeMD 15 1,519 08-16-2025, 05:01 PM
Last Post: bflint
  Pictures of OEM Rear turn signal mount Houndwheels_imp 8 764 09-12-2023, 10:28 AM
Last Post: Houndwheels_imp
  removing rear turn signal modmaster_imp 12 995 04-20-2023, 10:17 AM
  After market turn signal on CB 1100rs 2018 not working Saltani_imp 6 556 12-08-2022, 09:24 PM
Last Post: leung_imp
  Headlight shell acc connector HBFL_imp 2 336 08-28-2022, 08:18 PM
Last Post: HBFL_imp
  Turn Signal Switch and Horn Button Locations pekingduck 26 1,908 07-12-2022, 08:04 PM
Last Post: tommymck
  2013 turn signal replacement RF(OEM) casey66_imp 17 1,287 01-15-2022, 01:31 AM
Last Post: Bazbro_imp
  obd connector andyoz_imp 12 998 07-12-2021, 09:59 AM
  Turn Signal Malfunction billyfinchapel_imp 5 561 05-04-2021, 01:51 PM
Last Post: billyfinchapel_imp
  rear signal assembly cj599_imp 14 1,024 03-19-2021, 08:14 AM
Last Post: cj599_imp
