05-24-2021, 03:22 AM
hi guys can anyone tell me where the obd connector plug is on a 2019rs cheers
obd connector
05-24-2021, 05:04 AM
It is a little red connector underneath the left hand side panel. You need to get a Honda motorcycle diagnostic plug to OBD convertor cable to use any software. I got one for a few euros from the usual Chinese outlets.
https://www.ebay.ie/itm/184620410694?has...SwU6lf~7IB
05-24-2021, 05:43 AM
(05-24-2021, 05:04 AM)Tev62_imp Wrote: It is a little red connector underneath the left hand side panel. You need to get a Honda motorcycle diagnostic plug to OBD convertor cable to use any software. I got one for a few euros from the usual Chinese outlets. thanks very much
05-24-2021, 11:42 AM
(05-24-2021, 05:43 AM)andyoz_imp Wrote:(05-24-2021, 05:04 AM)Tev62_imp Wrote: It is a little red connector underneath the left hand side panel. You need to get a Honda motorcycle diagnostic plug to OBD convertor cable to use any software. I got one for a few euros from the usual Chinese outlets. thanks very much Out of curiosity, does the 2014 also have an OBD port like this?
05-24-2021, 12:15 PM
If I recall correctly, Alain Lee indicated there wasn't, at least not until 2017.
05-24-2021, 12:31 PM
What Gold said, Whoops. Not an ODB port.
We do have a port, but you have to have Honda’s HDS tester, or an aftermarket one like Healtech makes.
05-24-2021, 04:02 PM
(05-24-2021, 05:04 AM)Tev62_imp Wrote: It is a little red connector underneath the left hand side panel. You need to get a Honda motorcycle diagnostic plug to OBD convertor cable to use any software. I got one for a few euros from the usual Chinese outlets. What software is needed to read faults and reset.
05-24-2021, 09:33 PM
Torque / Torque Pro should work.
05-25-2021, 06:37 AM
(05-24-2021, 04:02 PM)Mixagon_imp Wrote:(05-24-2021, 05:04 AM)Tev62_imp Wrote: It is a little red connector underneath the left hand side panel. You need to get a Honda motorcycle diagnostic plug to OBD convertor cable to use any software. I got one for a few euros from the usual Chinese outlets. What software is needed to read faults and reset. Sorry Mixagon, I have not got that far. I have a licensed version of a car scanner software programme and I was hoping it would pick up any error codes but no joy with that yet or a few others I have tried, still searching for something cheap and cheerful that uses a cable connection on a PC rather than BlueTooth.
07-12-2021, 04:44 AM
(05-24-2021, 12:31 PM)Lord Popgun_imp Wrote: What Gold said, Whoops. Not an ODB port. I came across this post and your response. So would a 4 pin cable (link below) not work with a ODB2 bluetooth on a 2013 CB1100 ? Im trying to get my phone to display RPMs, etc readings on an app like Torque but I haven't bought the cable since I've been doing research on which one I would need. https://www.ebay.com/itm/393290877118 |
« Next Oldest | Next Newest »
| Headlight shell acc connector | HBFL_imp | 2 | 258 |
08-28-2022, 08:18 PM Last Post: HBFL_imp |
| LED tail light connector | shahyaan_imp | 10 | 672 |
11-28-2020, 09:33 PM Last Post: shahyaan_imp |
| Help identifying electrical connector | postoak_imp | 8 | 353 |
08-13-2016, 02:09 AM Last Post: postoak_imp |
| fuel pump connector | wiredgeorge_imp | 10 | 466 |
12-13-2015, 10:30 PM Last Post: Lord Popgun |
| Taillight/Signal Connector Types | AzBob_imp | 3 | 277 |
11-09-2013, 06:17 AM Last Post: ron1100_imp |
| Headlight connector | 1100rider_imp | 3 | 237 |
10-16-2013, 09:10 PM Last Post: Lord Popgun |
