battery tender cable hook up
Under the left side cover is a little black cover over 2 cables my test light tells me that the one with the yellow fuse is pos and green fuse is neg, is this where to hook up battery tender lead?
Don't you connect it directly to the battery? Thats how I did mine.
(04-29-2014, 06:47 AM)Lord Popgun_imp Wrote: Don't you connect it directly to the battery? Thats how I did mine.
Yea thats fine but I think this way is ok too. Trying to see if anyone did it this way?
The harness comes with it's own fuse and is meant to be connected directly to the battery.
Tender & heated gear should be hooked up straight to the battery.
Got it guy's direct to battery, thank you all for your reply's
And there is a hole in the right rear fender which is a natural place to poke the connection out of.
[url=http://smg.photobucket.com/user/theferret111/media/Batterytenderpigtail_zps67f97fdc.jpg.html][Image: 82bb0260ffb0d7130939f8ef1f65e6c3.jpg]
(07-10-2014, 03:03 AM)The ferret_imp Wrote: Can't imagine how little air could get sucked into that rear facing hole at the back of the bike, but in 11,000 miles on 2 bikes, it has not seemed to be an issue.
Maybe that hole is intended to be a vent for battery gasses? As you stated, I cannot see it being critical for breathing.
  ABS , speedometer and battery Walter 10 809 05-02-2026, 01:29 AM
Last Post: Walter
  Yuasa Battery Life dave 28 2,706 04-01-2026, 04:44 AM
  "Seat Lock" cable unseated. 17-CB-002 10 1,045 08-27-2025, 08:19 AM
  Rattle on right side exhaust / battery CB1100i_imp 4 703 04-18-2025, 02:48 AM
Last Post: CB1100i_imp
  Battery jumper the Ferret 14 1,169 10-28-2024, 10:58 PM
  CB1100 SA-E 2017 Battery Davidjill_imp 1 297 08-01-2024, 02:33 AM
  Throttle cable exposed misterprofessionality 7 1,236 06-12-2024, 11:53 AM
  wonder battery The Gecko_imp 58 4,851 02-19-2024, 11:20 PM
  Could old/low battery trigger misfire and engine light? Motorsport3_imp 13 1,286 12-17-2023, 08:41 AM
Last Post: Jgarciajr40_imp
  GPS power cable The Gecko_imp 10 1,045 10-06-2023, 12:40 AM
Last Post: suhawk305
