Smooth Power III ( cheap)
In search of improving the small but present low throttle (lean ?) surge and better sound, economically, I have done the following mods.
1) added a 1.3 k ohm resistor in the IAT Sensor circuit.
2) blocked the pair valve air supply hose
3) installed an O2 Bypass resistor plug
4) drilled 25mm ( 1" ) holes into the baffles in the muffler at both
ends. The 'Walls' you see at both ends looking into the or inlet,
offset a bit inside.
Results are seat of the pants, no dynos nearby and not that anal about this.
Better throttle response, even down to below 2000 rpm in top( 5th)
gear. throttle stumble,hesitation or whatever between 2500 and 3000 rpm is 99 % cured.
engine is more responsive to throttle inputs and 'eager' to accelerate.
Mld to moderate sound increase at idle and hearable to about 40 mph when helmet noise blocks it out. The sound is like stock, only louder, not a deep rumble or loud bark like an after market exhaust.
Mileage appears to have increased about 2 MPG. 48 mpg on freeway, expressway keeping up with the faster traffic and 52 MPG,spirited riding on secondary roads. Just my results after a 338 mile day test ride.
If 2 semi mechanically skilled owners PM me their mailing addresses I will mail them a home made sensor resistor kit to install and try for their own evaluation. Locate IAT sensor plug under left side cover, unwrap tape, cut and strip one wire and screw resistor/ posilock assy on to wire ends. I will include pics.
(08-02-2014, 03:45 AM)CBXBob_imp Wrote: In search of improving the small but present low throttle (lean ?) surge and better sound, economically, I have done the following mods.
So I take it that the added resistor fools the Intake Air Temp Sensor into thinking that the air temp in the air box is cooler than it really is, thereby causing the ECU to richen the Air/Fuel ratio.
The other way to accomplish the same thing is to relocate the IAT to a cooler location. This was a common mod on my previous bike (Vulcan 1700).
You might want to keep an eye on your plugs for fouling, especially now that you don't have a closed loop system with an O2 sensor, but you likely are not richening the mix much beyond optimum anyway. The only drawback to this mod that I am aware of is that on some bikes the ECU may have trouble if you make some drastic elevation changes.
I selected the resistor to hopefully only fool the IAT sensor at higher temps when the ecu leans the mixture out more. The resistance values of the IAT sensor are non linear and shouldn't have much if any effect below 60 degrees F. Altitude changes should not be a problem because the MAP sensor is not disturbed. Open loop, which the ecu will now run in all the time instead of 50% or whatever is still programmed for emissions, but biased towards best power instead of the stoichiometric 14.7 ave used for best emissions. Some power commander type TFI modules disable the O2 sensor, but can only add, and not subtract fuel. Had some experience with this on my 1250 Bandit, and never had a plug problem except for The NGK Iridiums that looked fine but misfired, like lots others experienced. check HOLESHOT.COM. Thanks for your response and insight.
How about posting a sound clip of the drilled muffler? I drilled mine on the rear baffle but not the front, and I couldn't tell any difference in sound. I have noticed, however that it's getting slightly louder as I put more miles on, which I figured would happen.
Ck You Tube: CB1100 drilled muffler both ends
  GPS power cable The Gecko_imp 10 1,013 10-06-2023, 12:40 AM
Last Post: suhawk305
  Has anyone installed a power commander in? Doug Shepard_imp 3 500 08-10-2023, 07:20 AM
  Power source for oil indicator led norton1974_imp 1 276 12-31-2022, 10:07 AM
  Power Commander V question HBFL_imp 1 258 08-23-2022, 05:41 PM
Last Post: jtopiso_imp
  Power Commander Tune Maps. mvk24_imp 43 3,033 01-03-2022, 08:16 AM
Last Post: SoCal CB1100_imp
  2010 model Power Commander alternative? 83NZA_imp 7 609 08-03-2021, 02:04 PM
Last Post: Aussieflyer
  Smooth shifting DougsZ28_imp 16 1,357 07-09-2021, 07:32 AM
  Transmission power routing and speeds LakeWylieJoe_imp 6 636 01-10-2021, 10:30 AM
Last Post: jimgl3_imp
  Guhl Reflash vs. power commander with custom map. misterprofessionality 9 759 09-06-2020, 03:59 AM
  Cheap airflow / power gains PowerDubs_imp 7 607 07-21-2020, 01:59 AM
Last Post: Cobalt23_imp
