Power source for oil indicator led
Is the power source for the low oil, pressure LED light, the same one as the light in the tachometer? The light for the gauge works. There is a good ground from the gauge to the switch, the switch grounds as it should. Everything appears to be well connected, however, the light for the gauge does not light.
Any help with this will be very appreciate it
Does this help you any, Norton? http://cb1100forum.com/forum/showthread....#pid217528
  Rear indicator (Turn signal) relocation bracket 2013 model AndyBeeMD 15 1,507 08-16-2025, 05:01 PM
Last Post: bflint
  Broken indicator lens spechg 6 656 04-18-2024, 03:01 AM
  GPS power cable The Gecko_imp 10 984 10-06-2023, 12:40 AM
Last Post: suhawk305
  Has anyone installed a power commander in? Doug Shepard_imp 3 491 08-10-2023, 07:20 AM
  Power Commander V question HBFL_imp 1 247 08-23-2022, 05:41 PM
Last Post: jtopiso_imp
  Gear indicator Billie_imp 11 960 02-22-2022, 03:24 AM
Last Post: gswanson89_imp
  Another source for plug-in LED flasher unit. FLYTYM_imp 7 626 01-31-2022, 09:53 AM
  Power Commander Tune Maps. mvk24_imp 43 2,969 01-03-2022, 08:16 AM
Last Post: SoCal CB1100_imp
  2010 model Power Commander alternative? 83NZA_imp 7 585 08-03-2021, 02:04 PM
Last Post: Aussieflyer
  Service indicator - unleashed j3gq_imp 6 602 07-27-2021, 03:12 AM
