Has anyone installed a power commander in?
I had a power commander installed but having some issues now took it back to the shop. Response on the throttle changed and i killed the bike at lights like 5 times. I have never killed my bike at a light before in the years i have owned it. Anyone have a map that works great for a 14'? Shop is had it again for a few days so i think they are trying to work with PC. Anyway thought i would ask in the forum. I also added 2 teeth to rear sprocket https://i.imgur.com/seBkTFN.jpg
Back when I had the Kawi Vulcan 1500, I noticed it had a horrible knock at lower RPM, I looked about for a cost effective device to fix that. I found one on a Kawi forum that purported to work. Can't remember the name of it, but it had a four-pot control box. I installed it, and it worked OK but I could smell fuel when I stopped. I dialed back the amount of fuel it delivered until the smell went away, and it ran great without the knock. I'd hole-sawed the twin mufflers, it sounded fantastic, like an Italian sports car climbing hills.
(08-10-2023, 03:26 AM)m in sc_imp Wrote: get an auto tune. the directions from power commander suck BAD on the pc6 and it super glitchy OUT OF THE BOX, especially in the recommended lower rpm settings. I have mine sorted but it took FOUR MONTHS.
if you get an at, i have a map that works great. the power commander alone will fight the stock ecm using the recommendations they sent. Mine stalled, ran hot, had a hard time restarting, etc. I hope you had better luck than i did. Its super sweet now but holy cow i had to work for it.
http://cb1100forum.com/forum/showthread....hlight=pc6
Just got a message from my custom bike shop he just dyno tuned again and said it's ready i will let you know after i pick it up and test run it Thumbs Up
Sucks still have issues with throttle response at start like a hesitation and i kill it at times on take off now. Never had the issue before. Took it back he said he put it back to stock when i brought it in and it still does the same thing? I am kinda upset with the service i got
  Can a 2013 centerstand be installed on a 2014? WRXer_imp 1 259 11-19-2023, 04:24 AM
Last Post: WRXer_imp
  GPS power cable The Gecko_imp 10 984 10-06-2023, 12:40 AM
Last Post: suhawk305
  New exhaust installed bvictory_imp 22 1,846 07-31-2023, 02:32 AM
  Power source for oil indicator led norton1974_imp 1 263 12-31-2022, 10:07 AM
  Power Commander V question HBFL_imp 1 244 08-23-2022, 05:41 PM
Last Post: jtopiso_imp
  Power Commander Tune Maps. mvk24_imp 43 2,964 01-03-2022, 08:16 AM
Last Post: SoCal CB1100_imp
  2010 model Power Commander alternative? 83NZA_imp 7 579 08-03-2021, 02:04 PM
Last Post: Aussieflyer
  Transmission power routing and speeds LakeWylieJoe_imp 6 591 01-10-2021, 10:30 AM
Last Post: jimgl3_imp
  Guhl Reflash vs. power commander with custom map. misterprofessionality 9 737 09-06-2020, 03:59 AM
  Cheap airflow / power gains PowerDubs_imp 7 583 07-21-2020, 01:59 AM
Last Post: Cobalt23_imp
