 Axle diameters?? For new tool
http://www.bajanopinch.com/shop/
I need 17mm for my Honda XR650L (primary target for this tool) but if I can use it on the CB - great! But I can't find the diameters of the front and rear axles so I can order the proper sleeves. You guys wouldn't happen to know would you?
Sorry mate, I can't help you. The shop manual gives run out limits for the axles but not axle diameter. Short of pulling the axles and measuring, maybe contact Honda.
Cheers and good luck.
Push come to shove I'll pull the axle's, but being a lazy sort I thought I could avoid real work. Big Grin Most list on line are too dated to list the CB and as you found out, the shop manual has butkis on measurements save run out.
Thanks anyway.
  Oinker Chain Lube Tool Gone in 60 4 525 01-15-2025, 08:31 PM
  Rear axle diameter 2014 vs 2017 ashishNJ_imp 4 546 08-28-2023, 06:07 PM
Last Post: dopaytoplay_imp
  Tool Recommendations for CB1100 Yata-Garasu_imp 18 1,673 08-09-2022, 04:07 PM
Last Post: Yata-Garasu_imp
  Question for anyone w/ the OBD tool PowerDubs_imp 5 515 02-19-2022, 04:43 AM
  Spring Tool Houtman_imp 32 2,295 10-17-2021, 12:41 PM
  rear axle nut question binarkansas_imp 12 1,004 05-21-2021, 01:49 AM
  Rear Axle Nut Billie_imp 7 589 03-22-2021, 12:56 PM
Last Post: Billie_imp
  Healtech eSync tool- synchronize balance throttle bodies PowerDubs_imp 11 1,115 12-06-2020, 06:43 PM
Last Post: jtopiso_imp
  Fork Tube hex head bolt tool fitment ? bflint 8 768 11-30-2020, 06:24 PM
  Workshop Tool List for CB1100 ? bflint 19 1,393 11-20-2020, 12:49 PM
Last Post: bflint
