Question for anyone w/ the OBD tool
Does it show injector duty cycle?
And if so- does it log?
I can’t remember if it shows the DC, but it does log everything it displays(Healtech) and can be played back all you want.
This morning I fired up the Healtech software on my PC and it does have a parameter for Injector. Parameter is in ms. When the cursor is hovered over the Injector display it says : Fuel injection time (ms) Determined by the ECM at #1 cyl.
Thanks for your time!
(02-19-2022, 01:36 AM)Lord Popgun_imp Wrote: This morning I fired up the Healtech software on my PC and it does have a parameter for Injector. Parameter is in ms. When the cursor is hovered over the Injector display it says : Fuel injection time (ms) Determined by the ECM at #1 cyl.
Does it show injection time [ms] individually for each injector???
No. It shows one value and says it for #1
I had forgotten I have some run files I saved from the idle problem investigation. I’ll have to run one of them and see what shows there.
  Oinker Chain Lube Tool Gone in 60 4 471 01-15-2025, 08:31 PM
  Tool Recommendations for CB1100 Yata-Garasu_imp 18 1,507 08-09-2022, 04:07 PM
Last Post: Yata-Garasu_imp
  Spring Tool Houtman_imp 32 2,127 10-17-2021, 12:41 PM
  Healtech eSync tool- synchronize balance throttle bodies PowerDubs_imp 11 1,031 12-06-2020, 06:43 PM
Last Post: jtopiso_imp
  Fork Tube hex head bolt tool fitment ? bflint 8 673 11-30-2020, 06:24 PM
  Workshop Tool List for CB1100 ? bflint 19 1,308 11-20-2020, 12:49 PM
Last Post: bflint
  stock tool kit (if you can call it that) 12cb96vfr_imp 11 886 02-09-2019, 02:28 AM
  Tool Kit? Rexburgtom_imp 22 1,469 09-30-2018, 08:39 AM
Last Post: SportsterDoc
  Vessel Tool Discount Code 2017EX_imp 6 493 06-06-2018, 03:17 AM
Last Post: 2017EX_imp
  Tool Kit zippooriginal_imp 12 788 08-15-2016, 10:14 AM
Last Post: rboe
