83lbf-ft on the rear axle nut
Doesn't seem real snug...so I tighten it a little more(around 90). But it got me to wondering if you can bend the swingarm by over tighting. My other bikes the nuts seemed much tighter.Undecided
Good night man, 83 foot pounds is a lot! The 14's only call for 68 foot pounds I believe.
Its in the Service Manual.
Oh I know thats the spec, I just couldn't believe you didn"t think that was enough!
I'll back it off some. No since in taking a chance. Smile
My FZ-1 called for 108 ft lbs.... I dont think I ever tightened it over 80 ft lbs. Even then when out on the road, it was a bear to get loose with the factory tool kit, like when adjusting the chain while on a trip.
You need a fair torque wrench to get that 83 comfortably. As Ferret says, releasing it with what's in the OEM tool kit needs, for me at least, a little bit of the old pipe extension. It's enough.
I find 83 to be more than I would tighten without a torque wrench. You get a bit more leverage with a 1/2 torque wrench ( longer handle )than you would with a normal ratchet, could be why it feels like you could go more.
I always tightened the rear axle snug without a torque wrench and mine never came loose nor was an issue at the next chain check. So you never have to over tighten them. Sometimes I'll get a new bike and am amazed how over tightened some things are. Spec never feels like a bear did it.
In German we say: "Nach ganz fest kommt ganz lose", which is straight translated: "After firmly comes very loose" Big Grin
Easy does it.
  Rear axle diameter 2014 vs 2017 ashishNJ_imp 4 546 08-28-2023, 06:07 PM
Last Post: dopaytoplay_imp
  rear axle nut question binarkansas_imp 12 1,003 05-21-2021, 01:49 AM
  Rear Axle Nut Billie_imp 7 589 03-22-2021, 12:56 PM
Last Post: Billie_imp
  New Rear Tire and Rear Brake Pads memphismike_imp 5 571 06-11-2018, 09:35 PM
  front wheel axle spacer collars switched Searcher_imp 6 515 05-25-2017, 10:36 AM
Last Post: Searcher_imp
  Rear Axle Torque? JustPassinThru_imp 3 332 06-16-2015, 01:54 PM
Last Post: JustPassinThru_imp
  Front Axle Pinch Bolt Torque ? rocket_imp 8 718 03-16-2015, 11:32 PM
Last Post: rocket_imp
   Axle diameters?? For new tool rboe 2 345 09-07-2014, 11:56 PM
Last Post: rboe
  Rear Axle nut... HikerToo_imp 6 508 07-02-2013, 11:33 PM
