Adjusting the clutch (clutch lever)
I have arthritic hands. Not bad, but I don't like to "reach " to the lever when it is farthest away. I think that is when the adjuster is set to "1".
However, as I try different clicker positions I am having trouble getting the clutch to engage. First I notice the difficulty in finding Neutral. Then I notice the lever has to be squeezed to the handlebars to engage completely.
Can the clutch play be adjusted so I can actually "use" the different clicker positions?
How hard is it to do at home?
Since it is hydraulic, you can't adjust the engagement point. You can only change the angle of the lever with the dial adjuster. As the clutch wears some, it will get more obedient. I run mine on '3' and don't have issues. If you're still having problems getting the clutch to disengage, you can shim your rod between the master cylinder and handle. I'd be super careful though. Use a small piece of electrical tape in the cup of the the handle. Keep working your way up until you get the disengagement you like. I've never done this before, but my buddy did this on his CBR1000 with good results.
Make sure no air in system, if it is soft.
(03-31-2015, 05:01 AM)kDiqq_imp Wrote: Since it is hydraulic, you can't adjust the engagement point. You can only change the angle of the lever with the dial adjuster. As the clutch wears some, it will get more obedient. I run mine on '3' and don't have issues. If you're still having problems getting the clutch to disengage, you can shim your rod between the master cylinder and handle. I'd be super careful though. Use a small piece of electrical tape in the cup of the the handle. Keep working your way up until you get the disengagement you like. I've never done this before, but my buddy did this on his CBR1000 with good results.
You better make sure you have some freeplay between the master cylinder and the "shim" otherwise when it returns to the rest position and the lever bottoms out you may still have partial disengagement
  CLUTCH FLUID CHANGE SUPERCRUZ_imp 15 1,322 12-24-2025, 11:14 AM
  Replace clutch Lever Davidjill_imp 10 1,006 02-06-2025, 01:27 AM
  Clutch Plates finally going? misterprofessionality 12 1,084 11-22-2024, 07:49 AM
  Clutch fluid change CB1100@2013: photos valkyrie_rider_imp 0 251 02-13-2024, 10:27 AM
Last Post: valkyrie_rider_imp
  Clutch Fluid Wagonpeddler_imp 32 2,599 06-14-2023, 08:09 AM
Last Post: bvictory_imp
  Clutch Not Working Henrik_imp 7 659 04-24-2023, 06:43 PM
Last Post: Henrik_imp
  Clutch pull mpuhl_imp 4 519 02-21-2023, 10:48 AM
  Front brake lever ROCK hard ichiban_imp 37 3,951 02-10-2023, 10:54 PM
  Long shift lever Sam Mac_imp 1 273 02-08-2023, 08:30 AM
  Clutch slave cylinder gasket Maturecheese_imp 3 399 01-27-2023, 12:33 AM
Last Post: Maturecheese_imp
