valve stem
Rear valve stem has a habit of sticking when I check or fill the rear tire. Anyone change out the core before? Done it years ago on a car, just wondering if I could do it with a plain ol' auto parts core and tool.
Hoping on getting out next month for some rides and liked to fix it myself if possible.
Thanks!
Same as changing any valve stem core.
Thanks Randy, figured so but wanted to be sure since haven't had this issue before
(07-24-2015, 02:56 AM)gossman_imp Wrote: Thanks Randy, figured so but wanted to be sure since haven't had this issue before
If you plan to remove and replace the valve core anyway, you might want to consider installing some Ride-On Tire Sealant...cheap insurance and balances the tires too!
They provide the valve core tool with the kit, but new cores are up to you.
Update: changed it out without any issue. Hopefully I can get in a good long ride next week.
Word of advice - started running dyna beads in another, lesser quality bike in hopes of a smoother ride. Aware of some problems but thought it was worth the risk.
Checked air pressure - valve at 90 degrees - and dyna beads caused it to stick open! WTF!
Ended up pulling the valve stem - schrader valve - and replacing. Found beads stuck in valve.
Will use ride on or another additive but never dyna beads again.
  Valve Adjustment Shims dave 13 735 07-28-2026, 12:49 PM
Last Post: MagnaRider
  Valve Adjustment and Camshaft Removal dave 5 646 03-21-2026, 04:49 PM
  Valve Adjustment dave 6 875 08-29-2025, 10:46 AM
  Valve Cover Baffle lining ? bflint 6 978 07-26-2025, 11:27 AM
Last Post: bflint
  Valve Adjustment Intervals CBRider_imp 32 3,101 04-21-2025, 02:24 PM
Last Post: Jurlie_imp
  Valve Adjustment Tolerances - How Far Do You Go? dave 14 1,577 10-18-2023, 09:28 PM
Last Post: The Gecko_imp
  Observed Valve Clearance Cormanus 16 1,482 03-06-2023, 09:03 AM
Last Post: Tejas_imp
  The OBSERVED Valve Clearance thread Pterodactyl_imp 162 13,687 12-27-2022, 08:35 AM
  Checking valve clearances Maturecheese_imp 74 6,877 12-11-2022, 12:56 PM
  Valve noise (i think) Maturecheese_imp 6 662 07-08-2022, 03:41 AM
Last Post: 1973cb750
