Where to buy crankcase breather tube?
When I first brought my new bike home 6 months ago, it had an issue with bad gas which fouled the plugs, leading to fuel burning in the catalytic converter. Until the problem was fixed, the catalytic converter got very hot - so hot, it melted the crankcase breather drain tube that runs down to the bottom of the bike near the center-stand (right between the catalytic converter pairs on the '14 DLX).
So my crankcase breather tube is about 4 inches short and I'd like to replace it.
Went to Honda dealer, and he can't get it. He tried to order it, but what he provided was not the right sized tube. When I go to the online Honda parts store, it shows this:
[url=https://www.dropbox.com/s/mggm6qeqej0vzoy/Bulk%20Hose.JPG?dl=0]Bulk Tube
Anybody know where I can get a replacement for my melted crankcase breather tube?
It is basically bulk tubing with a plug in the end. If you can find the origin point, just remove the old one and make a new one out of tubing, adding the required 4" and reinstall. There isn't really anything special or specific to it.
That is what I found as well 8X12X140. What I take from that is 8mm inside diameter, 12mm outside diameter and 140mm in length.
I would think you could go to the local parts store and find something that would work if you bring the old piece in with you to compare it to. I would try the small engine fuel line to start as that is what this most resembles.
(10-14-2015, 12:08 PM)treytexag_imp Wrote: When I first brought my new bike home 6 months ago, it had an issue with bad gas which fouled the plugs, leading to fuel burning in the catalytic converter. Until the problem was fixed, the catalytic converter got very hot - so hot, it melted the crankcase breather drain tube that runs down to the bottom of the bike near the center-stand (right between the catalytic converter pairs on the '14 DLX).
ask your dealer to check his Honda parts information bulletins for a new bulk hose listing part number for emissions qualified hose . now days any fuel related hose or fuel tank is made of a special material that does not breath fumes to meet CARB and federal regulations. his parts info may not be as up to date and the new hose material is listed on his Honda parts information bulletin.
Paul
OK guys, really good info here. I was wondering if the numbers on the part listing had anything to do with size.
Also, excellent point on the emissions qualified hose, and any potential parts bulletin - I will follow up on both of these.
Kmoney, Randy and Paul - thanks a bunch for the assist. I'll see what I can find out on this.
  Right Crankcase Cover missing from service manual? bflint 4 620 07-30-2025, 11:55 AM
Last Post: bflint
  Left Side Crankcase Gasket Part number. jbird06_imp 1 304 03-26-2024, 08:56 AM
  CB1100ex Tires pressure, when changed tube to tubeless tory_imp 10 815 10-09-2023, 07:51 AM
  2014 CB1100 Right crankcase cover msundst_imp 16 1,234 06-03-2023, 06:09 AM
Last Post: TX Silver_imp
  2017 tube type tires Mafd2_imp 4 470 02-08-2023, 01:10 PM
  Fork tube rust melfl_imp 8 702 12-23-2022, 04:41 AM
Last Post: redbirds_imp
  Fork Tube hex head bolt tool fitment ? bflint 8 658 11-30-2020, 06:24 PM
Last Post: jtopiso_imp
  Fuel Tank overflow drain tube. zirconxi_imp 11 834 05-29-2020, 11:36 AM
Last Post: LakeWylieJoe_imp
  Throttle tube easy to fit? Buzzard Biker_imp 9 613 02-28-2020, 11:21 PM
Last Post: Bazbro_imp
  Colour code for grey crankcase Mabel_imp 10 1,073 08-27-2019, 01:17 AM
Last Post: Frulk_imp
