2014 CB1100 Right crankcase cover
Hello
I need to remove and reinstall my right crankcase cover and wanted to know if i need to drain the oil and reinstall with a gasket? I assume so but seeing as this is the first time i have worked on a motorcycle im not sure what to expect. i attached a picture for reference. Thanks!!
On the right side are the larger clutch cover and the smaller ignition cover. Honda does not use a gasket on either, or on the left side engine cover. Instead, they use a thin bead of liquid, non-drying gasket sealant (3 Bond 1207B). On the ignition cover, be sure to put a bead of sealer in the well where the wires come out of the case cover.
….and yea- drain your oil if pulling the clutch cover
Thank you for the advice! Very helpful. Another thing would you guys know where I should look for a seat and exhaust upgrade? Looking for a more comfortable seat and a louder exhaust.
If it's the clutch cover you're removing, drain the oil as Power Dubs says, but might be easier doing it on the side stand so residual oil is not constantly dripping across the gasket surface.
Also, for your seat and exhaust questions, I'd search past threads, as there are lots like them. Or start a new thread.
Let us know how it works. I wanted to remove the ignition cover. Hit it many times with a rubber mallet without success.
One of these days, I need to remove my ignition cover. I get a very slight oil weep out of the top where the wires come through.
For now, I'm calling it "character", and wiping it off after each ride.
(05-23-2023, 02:09 AM)Gone in 60_imp Wrote: One of these days, I need to remove my ignition cover. I get a very slight oil weep out of the top where the wires come through.
Gone: You speak like a Guzzi owner. Big Grin
I had a BSA 750 Triple that did that, only it weeped enough to stain one leg on all my jeans lol
I imagine anything old and British or Italian would fit that description.
My old forklift leaks. Probably because it has "Lucas" printed on parts of the hydraulic system.
  Right Crankcase Cover missing from service manual? bflint 4 648 07-30-2025, 11:55 AM
Last Post: bflint
  Left Side Crankcase Gasket Part number. jbird06_imp 1 319 03-26-2024, 08:56 AM
  2014 CB1100 - rotational vibration/wobble - flat spots in tires? rozbabbo1100_imp 7 626 08-04-2022, 10:10 AM
Last Post: 1973cb750
  2014 cb1100 Torque specs for two specific locations Dd808_imp 8 647 09-08-2021, 11:07 AM
Last Post: Dd808_imp
  2014 CB1100 Deluxe No front brakes Roger the shrubber_imp 16 1,041 08-05-2021, 02:01 AM
  2014 Right Side Cover--Red eddi0_imp 12 1,122 06-07-2021, 09:16 PM
Last Post: eddi0_imp
  CBS COMBINED BREAKING SYSTEM in CB1100 ex 2014 ?? Alfgaxatico_imp 4 439 12-26-2020, 08:55 AM
Last Post: 17-CB-002
  remove the valve cover from the frame (ex 2014) Enzofour_imp 20 1,328 12-02-2020, 02:06 AM
Last Post: Enzofour_imp
  2014 cb1100 frame fork stem specs ck1100-smithbros_imp 13 880 04-13-2020, 05:47 AM
  Colour code for grey crankcase Mabel_imp 10 1,102 08-27-2019, 01:17 AM
Last Post: Frulk_imp
