Right Crankcase Cover missing from service manual?
I can't find anything in the 2013/14 OEM CB1100/A/SA Service Manual that references how to remove (or install) the Right Crankcase Cover (next to the Clutch Cover).  All I can find is references to the timing hole plug that is screwed into the cover.  The other left side and right side aluminum covers all show pics on where the liquid gasket should be laid out on both the engine block and the cover.  Anything to do with the Right Crankcase cover and its' internally mounted ignition pulse generator seem to be MIA from the manual.  Thoughts? Smile
(07-28-2025, 03:49 PM)bflint Wrote: I can't find anything in the 2013/14 OEM CB1100/A/SA Service Manual that references how to remove (or install) the Right Crankcase Cover (next to the Clutch Cover).  All I can find is references to the timing hole plug that is screwed into the cover.  The other left side and right side aluminum covers all show pics on where the liquid gasket should be laid out on both the engine block and the cover.  Anything to do with the Right Crankcase cover and its' internally mounted ignition pulse generator seem to be MIA from the manual.  Thoughts? Smile
That should be in the ignition section regarding removal of the CKP sensor, chapter 17-9 in the 2013-2017 manual.
^^+1^^
http://cb1100forum.com/forum/showthread....case+cover
http://cb1100forum.com/forum/showthread.php?tid=12558
           "Drop a gear and disappear"®
'24 Kawi Z650RS - Hooligan®
            *Grand Chancellor*
Or, on this forum ...
https://cb1100forum.net/forum/showthread.php?tid=4750
https://cb1100forum.net/forum/showthread.php?tid=5189
https://cb1100forum.net/forum/showthread.php?tid=4258
Spot on Mr Peking D !   Thanks !
  Service manual Billie_imp 32 2,860 11-27-2025, 06:35 AM
Last Post: TheLegend
  OEM CB1100 Shop Manual pekingduck 5 727 07-25-2025, 10:01 AM
Last Post: Lunchbag
  Repair manual for 2017 RS TheLegend 21 2,347 07-10-2025, 05:58 PM
  Service Manual for CB 1100/A/SA 2013-2016 N4RN_imp 14 1,469 05-06-2025, 04:29 PM
Last Post: Karidis
  Workshop Manual and Parts Book 2017 on CB1100's sprint 5 579 01-13-2025, 06:10 AM
  User Manual ? Davidjill_imp 2 359 08-01-2024, 06:27 AM
  Left Side Crankcase Gasket Part number. jbird06_imp 1 316 03-26-2024, 08:56 AM
  How To do your own 600 mile service the Ferret 163 10,579 08-10-2023, 07:42 AM
  2014 CB1100 Right crankcase cover msundst_imp 16 1,269 06-03-2023, 06:09 AM
Last Post: TX Silver_imp
  2018 CB1100EX just collected from service Motorsport3_imp 5 550 05-10-2023, 11:25 PM
Last Post: Motorsport3_imp
