Reinstall Back Grab Bar Bolt
I'm installing a Givi back rack and got the grab bars off, but I'm having a tough time getting the nuts started on the two back bolts. I, or my wife, cannot get our fingers up under the welded housing on my 2014 black standard. Box end wrench hasn't worked either. Service manual just says to reverse the removal procedure. No tips
I know someone must have done this and I would greatly appreciate any advice.
This might help. Its in the How To section. I didn't re-read it though, and I don't remember any real problems doing my '13.
Good luck! http://cb1100forum.com/forum/showthread.php?tid=3465
Thanks for the link, it is useful and well done. Apparently the 2014 Std. is a little different. There is a welded three sided box around the nut on the rear bolts. When you put the grab bar back up and get the rack in place (it is very tight, hence the scraps) you have about 3/8 inch to get into the back of it mainly because of the fender. Looks like Honda should have welded those in also. I think I'm going to drop the rear fender.
Still looking for tips.
extendable magnetic pickup.
[Image: 40c0385549c35feaa8684abd72b61e5a.jpg]
Thanks for the advice. I tried one, but the tip liked the other metal as much as the nut. I couldn't get it positioned.
However, I did get the rack installed today. I folded and wedged small bubble wrap behind the nuts, It worked on one and fell out on the second. I had to loosen the rear fender and drop it down. That gave me enough room to get the bolt started and use a wrench to tighten it.
However, one of the Givi rack holes was off about a quarter inch and I struggled to get the last two bolts lined up. I chose to do the back one first and after many tugs of the rack, finally got it lined up and the bolt through. The last bolt was in front with the welded nut. I got it in, but may have cut new threads. It went in tight. I'll find out if I ever take it off.
Bottom line is I like the look of the Givi back rack and the small rise, so my wife doesn't fall off. But they say in their very few instructions, each rack is hand welded and may have some variance for each model. Thanks to all who helped.
Well, at least the end result looks nice! Thumbs Up
I like that GIVI rack on your bike.
Since the rack angles upwards on a stnd 2014 like shown above,
do you suppose that this rack could have been made for a DLX/EX?
Or is the upwards angle how Givi designed it?
Anyone know of a pic showing that Givi rack on a DLX/EX?
I would like to get that rack for my DLX, if someone's installed this before.
THX!
I found this: http://cb1100forum.com/forum/showthread....3#pid46163
I really like the Fehling rack Django has on his EX which looks very similar to that one (only without the rear supports and which I think mounts easier) but can't find anyone in the US that sells them.
A quick Google search shows Webike has Fehling. Mr. T could most likely get you one. AND they have these things called airplanes that can actually fly over the ocean from Japan and a man will personally deliver it to your house! Smile
  Front sprocket bolt cant be moved misterprofessionality 55 4,489 03-13-2023, 12:18 PM
  Fork Tube hex head bolt tool fitment ? bflint 8 707 11-30-2020, 06:24 PM
Last Post: jtopiso_imp
  Engine mount bolt torque value TCinNC_imp 43 2,648 07-31-2020, 05:00 PM
Last Post: treedoc_imp
  Shock bolt torque HBFL_imp 9 709 04-11-2019, 07:04 AM
  Garnish/grab rails Chris Goldson_imp 2 277 01-05-2019, 11:00 AM
  2017 seat grab rail HBFL_imp 2 310 12-18-2018, 12:19 AM
Last Post: HBFL_imp
  3 in 1 Filter Wrench, 17mm Magnetic Drain Bolt, OEM Oil Filter, Crush Washers? LordWasr_imp 25 1,567 04-23-2018, 08:54 AM
Last Post: LordWasr_imp
  Side plate bolt Sonnyboy_imp 15 1,155 09-19-2017, 04:40 PM
Last Post: Sonnyboy_imp
  Handlebar Clamp Bolt size? Nappi185_imp 7 679 08-08-2017, 01:49 PM
Last Post: Nappi185_imp
  Battery bolt size Sam Mac_imp 6 522 11-11-2016, 04:49 AM
Last Post: Randy B
