Threads: 12
Do any of you know the size of the bolts for the battery connections? I want to add a battery tender pig tail and I will need to buy some ring terminals for the ends. I have a few of the pig tails with the clamps and am going to cut them off and replace with ring ends so that I can hook the pig tail to the battery. Thanks in advance.
Likes Given: 140
You can't take one out and look?
The head is 10mm, but I don't know the threaded shank size.
Likes Received: 608 in 273 posts
Likes Given: 785
shank size 6 mm
in nearly all instances for metric the head is 4 mm larger than the shank. So if it takes a 10mm wrench it's a 6 mm shank.
Likes Given: 140
Ahhh, good to know Ferret!
Threads: 12
(11-11-2016, 01:19 AM)Lord Popgun_imp Wrote: You can't take one out and look?
I could do that just didn't want to need to re-set the clock, just being lazy I guess.
(11-11-2016, 01:23 AM)The ferret_imp Wrote: shank size 6 mm
Thank you!
Threads: 129
I'm sure you already know this, but if you don't want to bodge your own set, you can buy pigtails with the ring terminals already installed for about $8. I didn't need longer screws when I installed mine.
Threads: 85
Likes Given: 129
