Handlebar Clamp Bolt size?
Are these M8? I want to see if I can mount one of these for my GPS: http://www.rammount.com/part/RAM-B-367U
http://www.partsfish.com/oemparts/a/hon/...top-bridge
I have one of those on my bike.
(08-07-2017, 06:04 PM)Aka Tsubasa_imp Wrote: http://www.partsfish.com/oemparts/a/hon/...top-bridge
This is awesome-THANK YOU!!!
(08-07-2017, 09:22 PM)Lord Popgun_imp Wrote: I have one of those on my bike.
Would you be able to post a photo of your set-up?
No photos since Photobucket messed us all up.
It isn't rocket science though. Just remove the plastic nut cap and remove the bolt (I did the upper right one). Install the ball and new longer bolt. Done Smile
Here is a post by a member that did it first, with pics. I did mine the same way. http://cb1100forum.com/forum/showthread....0#pid48800
(08-07-2017, 10:27 PM)Lord Popgun_imp Wrote: No photos since Photobucket messed us all up.
Thanks! Do you recall which bolt length you ended up using? (it comes with 55mm, 60mm, and 65mm lengths).
The 2 bolts I have left over are 65 and 60mm so I guess I used the 55mm. When you get done, the OEM plastic chrome nut cap will fit in the Ramball hole and finish it off.
Torque to 15 ft.lbs. If you remove them all, the books says tighten the fronts first, then the rears.
(08-08-2017, 06:29 AM)Lord Popgun_imp Wrote: The 2 bolts I have left over are 65 and 60mm so I guess I used the 55mm. When you get done, the OEM plastic chrome nut cap will fit in the Ramball hole and finish it off.
Yep, that's the one. I just read where the ball occupies 30mm, hence 25mm stock screw length + 30mm = 55mm. THANK YOU!
  Knocking noises; vibrations in the handlebar; oil sipping at valve lid gasket TheLegend 47 5,575 11-16-2025, 12:01 PM
Last Post: TheLegend
  CB1100 EX CA K handlebar switches sprint 7 603 02-25-2025, 10:36 PM
Last Post: sprint
  Front sprocket bolt cant be moved misterprofessionality 55 4,471 03-13-2023, 12:18 PM
  What is the Correct Chain Size for a 2014 Model? chync_imp 12 1,150 02-28-2023, 01:16 AM
Last Post: Maturecheese_imp
  Stock handlebar measurements misterprofessionality 5 559 04-12-2022, 05:47 AM
  Handlebar: passage of cables pericleromano_imp 7 603 11-03-2021, 02:50 AM
Last Post: j3gq_imp
  2013 versus 2014 wheel size Houtman_imp 19 1,583 10-08-2021, 05:11 AM
  Regina HPE chain-kit - looking forward to these coming in our size. Tev62 13 1,049 04-20-2021, 06:45 AM
  Handlebar bolts torque value? (CB1100RS -18) Olof_imp 3 408 04-03-2021, 01:35 AM
  Fork Tube hex head bolt tool fitment ? bflint 8 698 11-30-2020, 06:24 PM
Last Post: jtopiso_imp
