Red Line 5w Fork Oil Anyone?
Anyone using this oil in the front forks? Decided to get the Race Tech fork springs, and pretty sure I want to use Red Line 5W fork oil.
What not ask Race Teck what they suggest? I just for in an order for them to do my complete suspension. Ive read nothing but goood things about them.
(03-25-2016, 12:52 PM)kevbroce_imp Wrote: What not ask Race Teck what they suggest? I just for in an order for them to do my complete suspension. Ive read nothing but goood things about them.
They suggest their $30 per bottle of oil and need 2 of them...not going to happen
Never heard anything negative about Redline.
Red Line produces good oils, used their heavy duty stuff in my former Harley gear box.
You might want to check local dirt bike shops for different fork oils too. They seem to carry more choices since dirt bike guys must fiddle with suspensions a lot more.
Aloha,
Huladog
I used 5W Honda, SS-7. About $6 a bottle.
Here's my Race Tech fork spring photo essay: http://www.photosbytink.com/cb1100forksprings/
(03-25-2016, 02:38 AM)aschem_imp Wrote: Anyone using this oil in the front forks? Decided to get the Race Tech fork springs, and pretty sure I want to use Red Line 5W fork oil.
Just as a matter of interest are the Race Tech fork springs equal size for each fork leg or do they copy the Honda system of a shorter spring in one leg with a long spacer?
Race Tech are equal length, 335mm, and linear wound.
"2004-05 Honda 599-CB600F Hornet" http://racetech.com/ProductSearch/2/Hond...et/2004-05
If you have a 2014 Deluxe, you will have two different length OEM springs.
If your bike is a 2013 or 2014 Standard both OEM springs are the same length, 335mm.
See my chart for details:
Found Motul synthetic fork oil that is a light/medium weight (7.5-5wt) oil. Been snowing here, so I will probably do the springs in a few weeks.
http://www.amazon.com/Motul-100-Syntheti...B000VJM1E8
  CB1100 on-line manuals Cormanus 5 1,232 04-06-2026, 10:45 PM
  Fuel line retainer and dampener tod.branko_imp 16 1,253 07-04-2021, 04:28 AM
Last Post: tod.branko_imp
   Fuel line connection came undone and left me stranded! Riko_imp 33 3,614 12-04-2020, 12:29 PM
Last Post: 17-CB-002
  fork overhaul vs. fork replacement? misterprofessionality 20 1,734 09-20-2020, 07:13 PM
Last Post: DBM_imp
  Sometimes Ending Up Between Gears With Gear Indicator Line Blinking 2017CB1100EX-STL_imp 27 1,973 08-03-2018, 12:35 AM
Last Post: apex1_imp
  Removing Fuel line. J.W._imp 7 589 04-07-2016, 03:29 AM
Last Post: AzBob_imp
  CB1100 Owner's Manuals on line Cormanus 0 180 02-29-2016, 08:58 AM
  How do I unhook fuel line from tank.? Johnboy_imp 8 702 04-20-2015, 12:13 PM
Last Post: Johnboy_imp
  Undoing the Fuel Line Light_imp 4 373 02-20-2015, 08:12 AM
Last Post: Elipten_imp
  Tires without center line? xpacpal1x_imp 16 1,495 05-29-2014, 09:50 AM
Last Post: Red Mist_imp
