How do I unhook fuel line from tank.?
I have my tank almost off and cannot figure out how to unhook the fuel line from the tank ??? Can someone please show or explain that connection to me . .? Do I squeeze twist or what ?
Disregard.. I see the thread ... It just doesn't show exactly how to do it ..
Here's a little bit about it:
http://cb1100forum.com/forum/showthread.php?tid=5331
Good luck, JB. I watched a video, but didn't find it much help. The guy did it very quickly and there were no close-ups of what he did.
https://www.youtube.com/watch?v=-BsZk3Bq3Ok#t=77
First pull the flexible black piece out of the connector slightly.. Do not break it. Pinch the green tabs inward and pull the connection fee. It is not easy, and not much room. I prop up tank wit a small 2"x 4". Look in their with a flash light. The shop manual tell to lube the tube with some engine oil for assembly.
It does help to lube. Reverse order at assembly.
(04-19-2015, 07:26 AM)Elipten_imp Wrote: First pull the flexible black piece out of the connector slightly.. Do not break it. Pinch the green tabs inward and pull the connection fee. It is not easy, and not much room. I prop up tank wit a small 2"x 4". Look in their with a flash light. The shop manual tell to lube the tube with some engine oil for assembly.
Thank u so much
(04-19-2015, 07:16 AM)jerrycon_imp Wrote: Here's a little bit about it:
Thank u
Well I was just trying to wire up a receptacle for my cell phone or gps ... I bought a water proof cigarette plug with a handle bar mount ... I put it all back together as I was afraid I was going to break that fuel line ... I'd really like to see it done first ... I would be upset with myself if I broke that fuel line assembly ... Lol
I do appreciate your info Elipten ,,, I had the tank propped up with a 2x4 and a flashlight looking at the connector ... I was just so afraid of breaking it ,, I will try again another day ... Thanks
It is hard to pull apart. Give it a rub of oil when putting back together it helps!
Johnboy,
I had trouble when I did this too. For me, this thread was most useful:
http://cb1100forum.com/forum/showthread....=Fuel+Line
What especially helped me was the part that says: "If the connector does not move, keep the retainer tabs pressed down, and alternately pull and push the connector until it comes off easily."
The "pull and push" part was key for me, because I was just pulling it before (for a half an hour). When I pulled then pushed, back and forth, it came right off in a few seconds.
Good luck!
The manual also says DO NOT USE PLIERS (or tools, can't remember exactly). You can buy new pieces if you manage to mess them up...
After all the trouble and time taking it off, when it just clicks back in upon re-assembly, you will think "that's it?"
No tools needed, and it would be hard to get tools in there.
(04-19-2015, 01:05 PM)Light_imp Wrote: Johnboy,
Good luck!
Thanks ! This was very helpful !
(04-19-2015, 08:59 PM)Lord Popgun_imp Wrote: The manual also says DO NOT USE PLIERS (or tools, can't remember exactly). You can buy new pieces if you manage to mess them up...
Thanks for the info !Thanks
  CB1100 on-line manuals Cormanus 5 1,230 04-06-2026, 10:45 PM
  CB1100RS fuel tank rust Narciso 12 1,357 09-27-2025, 02:06 PM
Last Post: tdbru
  CB1100 fuel tank upgrade johnnyH_imp 3 445 03-13-2024, 01:31 AM
  Fuel line retainer and dampener tod.branko_imp 16 1,253 07-04-2021, 04:28 AM
Last Post: tod.branko_imp
   Resistance of Fuel Tank 2014CB1100 itsok_xman_imp 7 656 04-01-2021, 02:34 AM
Last Post: itsok_xman_imp
   Fuel line connection came undone and left me stranded! Riko_imp 33 3,607 12-04-2020, 12:29 PM
Last Post: 17-CB-002
  Fuel tank interchangeability? Model difference questions.... 2014ltdltz 5 699 10-12-2020, 11:59 PM
Last Post: 2014ltdltz
  How to empty the fuel tank? Ulljanrich_imp 23 1,827 07-20-2020, 04:45 AM
Last Post: TXBikerGuy
  Fuel Tank Removal Gabby_imp 11 927 06-19-2020, 10:54 AM
  Fuel Tank overflow drain tube. zirconxi_imp 11 901 05-29-2020, 11:36 AM
Last Post: LakeWylieJoe_imp
