Threads: 126
Likes Given: 1
I'm a bit torn about my upcoming suspension upgrades and wanted to see if anybody could offer cogent advice. I'd initially planned to follow in some others footsteps and upgrade my front forks using the '17 cb1100 set since they bolt right on with no issues. However, It was posed to me that I should just change to upgraded springs and change the oil and it would achieve equivalent results after some adjustments. Is this true? For what reason would somebody replace the entire fork if this was an option? what else can i do to improve my front suspension without replacing it? primarily i'm interested in dampening on country roads and corner stability.
Likes Received: 587 in 321 posts
Likes Given: 992
Threads: 126
Likes Given: 1
Thanks Peterbaron. Reading all that has me understanding better why somebody might just replace the forks rather than going through all that. my head spins at the idea of disassembling the forks multiple times and trying to dial in adjustments. The way it was explained to me previously you could drop in new springs and new oil without even pulling the forks off the bike. But i'm reading through many of those threads that there's a whole process of revalving involved...yikes.
Threads: 115
MisterP , if money is not a big issue I would put just the 2017 forks into your bike , very easy and quick and you could perhaps sell your old ones. PS I am in Charleston at the moment at our daughters on Johns Island at 7 pm when I post this.
Threads: 125
"However, It was posed to me that I should just change to upgraded springs and change the oil and it would achieve equivalent results after some adjustments"
If all it took was a change in spring rate, oil weight and height...then that's what Honda would have done.
Modification kits have been around for decades (gold valve)....they help, but are band-aids, not new technology.
Every review I've read about the Showa dual bending valve forks has been favorable- both on our Honda's and the Harleys.
My personal experience has been that they improve the ride with no downside.
Buy em, swap em, sell your stock forks.
Threads: 23
It comes down to how much money you have to spend and the gains you wish/expect to make.
I spent around AU$350 on PD valves and fork springs and I am very happy with the result, straight out of the box, no adjustments, IMO a 50% improvement over stock in both comfort and in handling round bends.
Threads: 126
Likes Given: 1
(09-18-2020, 09:13 PM)ozigoo_imp Wrote: It comes down to how much money you have to spend and the gains you wish/expect to make.
No adjustments? Thats interesting. Do you have a link to the parts you purchased?
(09-18-2020, 10:05 AM)PowerDubs_imp Wrote: "However, It was posed to me that I should just change to upgraded springs and change the oil and it would achieve equivalent results after some adjustments"
I trust you. Everything I've heard about those shocks are that they're a great improvement. However. Your last line is really the rub. I cant sell the stock forks. I need those in case of a crash. I've kept all my stock parts for that reason.
(09-18-2020, 09:03 AM)Houtman_imp Wrote: MisterP , if money is not a big issue I would put just the 2017 forks into your bike , very easy and quick and you could perhaps sell your old ones. PS I am in Charleston at the moment at our daughters on Johns Island at 7 pm when I post this.
Welcome to Charleston!
I agree with the sentiment on replacing the forks....it seeems sooooo much easier. If I can get similar results for half the money, though, i have to explore it. I can afford either choice, but that doesnt mean I don't care.
Threads: 125
(09-18-2020, 10:21 PM)misterprofessionality_imp Wrote: (09-18-2020, 09:13 PM)ozigoo_imp Wrote: It comes down to how much money you have to spend and the gains you wish/expect to make.
Umm.... if you modify your stock forks....then crash, what happens then?
Threads: 63
Likes Given: 8
Hello MP. I changed my 2014 forks to 2017 forks, and I am very pleased with the result. I am fairly mechanically inclined, and I do enjoy working on my motorcycles (I own 7), but the older I get it seems the less I enjoy working on them, and the less time I have available to work on them. One can spend hours of testing and going through various adjustments on stock shocks to achieve a satisfactory result (my dirt bikes have way more adjustments than the CB1100). If you limited your changes on the CB to just changing springs, oil viscosity, and oil height, you could be talking a lot of time here. Add a re-valve kit installation, and the potential to have to perform multiple adjustments to the new valving before achieving a satisfactory result, then you're talking some serious time. Throw in the cost of the re-valve parts, springs, fork oil, and your time, is it worth it? It wasn't to me. The fork swap took about one hour, and I was done. The deciding factor for me to buy the 2017 forks was I discovered pitting on one of my fork tubes, and I knew a leaking seal would occur soon, and the tube would have to be replaced. I live in S. Ca, my bike is garage stored, and it has only been drizzled on twice since I bought it new, so there was really no good reason for the pitting. I believe that two other members posted about issues with their fork tubes pitting or the chrome wearing off, and I just didn't want to deal with this (the "time" issue again). Hope this helps.
Threads: 126
Likes Given: 1
(09-19-2020, 12:47 AM)PowerDubs_imp Wrote: (09-18-2020, 10:21 PM)misterprofessionality_imp Wrote: (09-18-2020, 09:13 PM)ozigoo_imp Wrote: It comes down to how much money you have to spend and the gains you wish/expect to make.
Then I dont have spares. That doesn't mean I'd get rid of them if I had the opportunity to have spares. Its just smart to keep them if you care about the bike being totalled. For me, I dont ever want to lose this motorcycle, even if the insurance totals it.
