Removing Fuel line.
Hi I have tried today to remove the Fuel Tank off my 2014 CB1100, I am struggling to remove the fuel line fixing. Can anybody talk me through the process. You seem to have to press two sides of it and pull, I tried this but it doesn't seem to want to move.
Appreciate any help.
Regards
J.W.
http://www.cb1100forum.com/forum/showthr...p?tid=5331
Read the how to, should help. Good luck!
https://youtu.be/zfuYTjftkDo?t=91
Should show you how -- off and on. The only thing missing from the video is that you have to remove the rubber cover that the CB has, which prevents the two tabs from being pushed together.
The service manual also recommends you replace the little retainer and the rubber cap when you take it off,
I did they don't cost much and you don't have to feel bad about being a little ruff with the old one.
Excellent thank you very much for the replies, I didn't try to remove the black rubber tab, so I suppose that's where I went wrong.
Regards
J.W.
The black rubber tab just moves out of the way so you can squeeze the plastic tab. I had to use pliers because I simply wasn't strong enough in that tiny space to do it any other way. Unfortunately, with metal pliers, you risk causing a spark and blowing yourself up, however, if you get a pair of plastic pliers (often used in electrical work), you can get it done.
The book says Do Not Use Pliers. I think so you don't mess up anything, but the blowing up thing is a consideration Smile
(04-05-2016, 08:58 AM)Lord Popgun_imp Wrote: The book says Do Not Use Pliers. I think so you don't mess up anything, but the blowing up thing is a consideration Smile
Yeah, I'm reasonably certain the manual says not to use pliers because it's metal-on-metal and you can cause a spark and create an impromptu Fourth of July display. I guess you could also squeeze too hard on the wrong thing and crush the fuel line.
All that being said, I actually used metal pliers, didn't blow anything up, and didn't crush anything. I now have plastic ones in case I need to do it again.
  CB1100 on-line manuals Cormanus 5 1,249 04-06-2026, 10:45 PM
  removing rear turn signal modmaster_imp 12 1,060 04-20-2023, 10:17 AM
  Fuel line retainer and dampener tod.branko_imp 16 1,262 07-04-2021, 04:28 AM
Last Post: tod.branko_imp
  removing both wheels Tom_imp 20 1,719 05-21-2021, 01:07 AM
   Fuel line connection came undone and left me stranded! Riko_imp 33 3,695 12-04-2020, 12:29 PM
Last Post: 17-CB-002
  Removing bar end mirrors - need advice Endeavour_imp 5 496 08-15-2020, 02:20 AM
  Removing stickers ncgeezer_imp 14 953 06-03-2019, 08:07 AM
  Sometimes Ending Up Between Gears With Gear Indicator Line Blinking 2017CB1100EX-STL_imp 27 1,993 08-03-2018, 12:35 AM
Last Post: apex1_imp
  removing rear wheel on CB1100NA (RS) Care needed Macduff_imp 1 249 07-28-2017, 11:54 PM
  Removing Cat Converter HBFL_imp 1 221 09-24-2016, 12:56 PM
Last Post: Ben70_imp
