FRONT BRAKE TIGHTER
I changed the brake fluid on my 2014 CB1100 and the front brake lever has some travel but not as much as I think it should. It seems "tighter" than it should be.
Is that normal when put the fresh oil?
I checked the manual, which discusses the adjustment wheel (1-5) but this adjustment doesn't seem to help.
Any advice?
Normally when any vehicle gets a brake flush and bleed the system gets tighter. Especially if there was any air in the lines. Like my rear brake had from the factory.
yes bleeding the brake system will firm up the lever as air is purged from the system.
the adjustment wheel on the lever simply moves the lever closer or farther from the bar depending on rider preference.
  Front ABS Brake"Rain Stick" noise bflint 3 469 07-12-2024, 08:36 AM
Last Post: Race_ca1
  Front brake inconsistent resistance ChiefJP_imp 16 1,393 06-14-2023, 07:46 AM
Last Post: bvictory_imp
  Sqealing front brake thop_imp 10 1,001 06-14-2023, 07:34 AM
  Front brake lever ROCK hard ichiban_imp 37 3,898 02-10-2023, 10:54 PM
  Front brake.... pulsating??? mattmcuomo@yahoo.com 12 785 05-11-2020, 03:51 AM
Last Post: max
  Front Brake Drag 2017EX_imp 16 989 04-10-2020, 01:22 AM
  Correct part number for front brake pads Frulk_imp 7 647 02-18-2020, 08:06 AM
Last Post: iamheero_imp
  Replaced front brake pads for 1st time at 20K miles Frulk_imp 15 1,060 01-04-2020, 02:15 AM
Last Post: Bheezy27403_imp
  How to change front brake pads 2013 abs ? 562loosenoodle_imp 20 1,256 02-04-2019, 01:47 PM
  Bike fell over, broke the front brake lever and bent the rear brake jlouis976_imp 24 1,730 09-14-2018, 12:35 AM
