Headlight Problem
Just an FYI, if your hi beam dash light shines when your switch is on low beam, that is a warning that the 3 prong wire connector is not making proper connection to the headlight bulb. Thus, the bulb will not light up. I changed bulbs recently and pushed the connector too far onto the bulb and experienced this. Removal of the connector and slightly bending the parallel prongs on the bulb created enough tightness to eliminate this problem.
Thanks for the heads up
(07-11-2016, 01:10 PM)White Dog_imp Wrote: Just an FYI, if your hi beam dash light shines when your switch is on low beam, that is a warning that the 3 prong wire connector is not making proper connection to the headlight bulb. Thus, the bulb will not light up. I changed bulbs recently and pushed the connector too far onto the bulb and experienced this. Removal of the connector and slightly bending the parallel prongs on the bulb created enough tightness to eliminate this problem.
Thanks for that, also keep in mind bulbs do burn out. If your high-beam indicator doesn't come on, the bulb has failed. Happens. Quite a bit of vibration going on up there.
  CB1100 Idle speed instability problem ericlo69_imp 1,434 116,767 07-26-2026, 01:51 AM
  idle problem update 1973cb750 37 2,013 05-12-2026, 08:38 PM
Last Post: rdprdp01
  Headlight shell Lord Popgun 11 1,503 10-08-2025, 01:17 PM
  2017 MY CB headlight upgrade. 17-CB-002 16 2,198 09-06-2025, 05:00 PM
  Chain or sprocket problem ? The Gecko_imp 14 1,197 07-30-2024, 10:05 AM
  O ring chain problem Mixagon_imp 7 628 10-17-2023, 07:28 AM
  About the problem of high idling. (2014 cb1100ex) DDUMZI_imp 62 4,541 08-02-2023, 05:38 PM
Last Post: DDUMZI_imp
  auxiliary 12v in headlight shell Maturecheese_imp 6 592 03-25-2023, 07:14 AM
  May have a problem the Ferret 12 838 01-20-2023, 04:53 PM
Last Post: max
  Delay when using headlight switch? Jgarciajr40_imp 15 1,049 12-05-2022, 07:11 AM
Last Post: max
