May have a problem
On today's 52-mile ride, at about the 40 mile mark I was running 45 mph and came up behind some slower traffic. I pulled the clutch in and started down shifting and the bike stalled. As a was rolling I let out the clutch and it bump started and continued running. A few miles later I came up behind a school bus and same thing, pulled in the clutch started downshifting and the bike stalled, but bump started. When I pulled into my drive it happened a 3rd time. I hit the kill switch off and on and the bike started and idled normally. I waited a half hour went out and started the bike and it idled normally.
So what do you guys think is going on?
2014 CB 1100 Deluxe 69,300 miles.
Kill switch on the handlebar is a good thought. I'd also look at the kill switch on the side stand - perhaps gooped up with road dirt?
Kill switch.
Had that happen on an '86 Yamaha Virago 1100, but in my case it wasn't the actual switch, but the switch circuit (wire).
Not hard to see switch gear getting soiled up.
I’ve had an occasional problem with the connection on a wire that connects the kill switch and the clutch occasionally. The bike won’t start with the bike in gear and the clutch pulled in. It’s one of two wires around the clutch lever.
Perfect excuse to put the more historically visually appropriate '13 controls on.
Not to mention fixing the dumb horn button on the '14...
[quote='PowerDubs' pid='330638' dateline='1674180247']
If my memory is correct, I think Mr. Ferret did put the 2013 LH side switch assembly on his bike (and so did I).
You’re right, Dave. Indeed, I think Mr Ferret may have been first out of the blocks.
I did put a 13 switch on early on back in 2014, however, in 2021 I switched it back to the 2014 switch, to match the NC 750's switch layout.
today I played with the emergency stop switch and noticed sometimes when switching it to the run position I couldn't hear the fuel pump. I also checked the two snap connections on the clutch interlock switch and all seemed good there. Anyhow once the fuel pump cycled it would start and idle fine so I got dressed, fired it up and took it for a 24 mile test ride with lots of slowing down and down shifting, and pulling the clutch lever in and coasting at idle. Ran fine, no stalling.
I think I may have a failing r/h switch assy? Sound right to you guys?
Sounds about right. Maybe a good cleaning will take care of it. The switch. Cause we know the bike ain’t getting a cleaning!!! Big Grin
  CB1100 Idle speed instability problem ericlo69_imp 1,434 117,275 07-26-2026, 01:51 AM
  idle problem update 1973cb750 37 2,066 05-12-2026, 08:38 PM
Last Post: rdprdp01
  Chain or sprocket problem ? The Gecko_imp 14 1,211 07-30-2024, 10:05 AM
  O ring chain problem Mixagon_imp 7 633 10-17-2023, 07:28 AM
  About the problem of high idling. (2014 cb1100ex) DDUMZI_imp 62 4,611 08-02-2023, 05:38 PM
Last Post: DDUMZI_imp
   2017 EX Headlight Dimmer Switch problem? sleeper_imp 24 1,813 10-08-2022, 12:27 PM
  Fast Idle Problem Solved Nachodaddy 17 1,449 10-08-2022, 09:18 AM
  Another High Idle Problem emptysea 60 3,962 07-05-2022, 11:41 AM
  Tail light install problem iamheero_imp 9 714 11-27-2021, 02:58 AM
Last Post: Bazbro_imp
  Rear indicator design problem Mixagon_imp 5 498 06-19-2021, 04:23 AM
Last Post: Mixagon_imp
