CB900C- oil on the left side engine
Hello,
I was trying to investigate an annoying sound which I thought was from the starter engage gear on the left side of the engine. So I remove the cover by undoing the six 5/16" head bolt that holds the cover to the engine. I wasn't expecting oil in there but alas as soon as the cover was completely removed the oil started pouring.
Is it normal to have oil in there or is there something wrong with the engine? The motor runs tops though.
Thanks a lot in advance for any info regarding this.
Some of our members might know, but this forum is for the 2010-2017 CB1100.
Welcome though! I hope you get your answer.
pretty sure that's normal. whenever you see many bolts placed that close together, there's oil in thar!
take the stator cover for example, only 3 bolts about 3 inches apart if I recall correctly... no oil.
(05-01-2017, 05:18 AM)Lord Popgun_imp Wrote: Some of our members might know, but this forum is for the 2010-2017 CB1100.
thanks for the warm welcome.
Big Grin
(05-01-2017, 06:17 AM)jimgl353_imp Wrote: pretty sure that's normal. whenever you see many bolts placed that close together, there's oil in thar!
Welcome gmmy1515. We're pretty friendly, even if you don't have a CB1100.
The guys on the CB750C/CB900C Forum have all the info you need.
Check it out here: http://www.cb750c.com/
  Left side cover removal jeffmazz_imp 24 2,006 07-09-2025, 03:37 PM
Last Post: bflint
  Left Side Crankcase Gasket Part number. jbird06_imp 1 314 03-26-2024, 08:56 AM
  Question on replacing engine side cover Ollie 11 764 01-10-2022, 11:21 AM
Last Post: Ollie
  Tank decal and the junk left behind Gordo_imp 13 1,020 09-06-2021, 02:29 PM
  left crank cover calipo223_imp 3 370 05-05-2021, 06:29 AM
   Fuel line connection came undone and left me stranded! Riko_imp 33 3,535 12-04-2020, 12:29 PM
Last Post: 17-CB-002
  2013 cb1100 Left Directional Light wont cancel. M3-SRT8_imp 15 1,109 08-01-2020, 07:16 PM
Last Post: max
  Location of Engine Number on Engine? cb1100_dude_imp 2 324 05-29-2019, 01:44 PM
Last Post: cb1100_dude_imp
  Side engine cover questions. pedro_k_imp 10 557 08-22-2018, 11:57 PM
  Replacing Left Side Engine Cover will866_imp 4 350 03-29-2018, 10:36 AM
Last Post: jeffmazz_imp
