New Power Commander FC
Hello,
anyone knows anything about the new Power Commander FC (EFC16040)?
Rolleyes
In Italy, it will cost about 41% less than the classic Power Commander V (E16-040) and, apparently, do the same things.
Cool
Here's the info:
http://www.powercommander.com/powercomma..._pcfc.aspx
And here's the one for the CB:
http://www.powercommander.com/powercomma...rcommander V&notes=91,
It appears the major difference is that you cannot program it via PC, which also suggests you can't program it on the fly when doing dyno runs. However, if you have maps already, it could work. At $250 plus shipping (MSRP, actual prices from distributors may be lower), that's quite a savings over the standard unit.
(04-02-2014, 12:24 AM)The Spaceman_imp Wrote: Here's the info:
PCFC seems to be capable to store up to 10 different maps uploaded by PC (against two of PCV).
The difference is that you can adjust carburation on the fly without a PC, simply tuning the knobs with a screwdriver.
I think the main different feature is that the PCFC unit does not work with any of the PCV accessories (SFM, ignition module, shifter, LCD).
Rolleyes
This thing looks pretty cool. Price is more in line with what the market is demanding. An ECU reflash is about the same $$ or more, but will do a lot more. But if ya just want to do the air filter and slip-on, your $250 gets you optimization and peace of mind.
A dyno run after would be a good idea.
$250?
You can get a PC V from Motomummy.com for $269.
So then I wonder what motomummy will be selling the FC model for?
Here, PCV is for 339,00 € and PCFC for 199,00 €.
Rolleyes
Good point Guth.
My guess is $150..
(04-03-2014, 02:28 PM)Guth_imp Wrote: So then I wonder what motomummy will be selling the FC model for?
I found one supplier for $236. Dennis Kirk, not moomommmummy.
(04-01-2014, 08:41 PM)Mad Max_imp Wrote: Hello,
Rolleyes
Cool
anyone know if it gets rid of the speed limiter??
  GPS power cable The Gecko_imp 10 1,049 10-06-2023, 12:40 AM
Last Post: suhawk305
  Has anyone installed a power commander in? Doug Shepard_imp 3 509 08-10-2023, 07:20 AM
  Power source for oil indicator led norton1974_imp 1 285 12-31-2022, 10:07 AM
  Power Commander V question HBFL_imp 1 266 08-23-2022, 05:41 PM
Last Post: jtopiso_imp
  Power Commander Tune Maps. mvk24_imp 43 3,171 01-03-2022, 08:16 AM
Last Post: SoCal CB1100_imp
  2010 model Power Commander alternative? 83NZA_imp 7 647 08-03-2021, 02:04 PM
Last Post: Aussieflyer
  Transmission power routing and speeds LakeWylieJoe_imp 6 657 01-10-2021, 10:30 AM
Last Post: jimgl3_imp
  Guhl Reflash vs. power commander with custom map. misterprofessionality 9 805 09-06-2020, 03:59 AM
  Cheap airflow / power gains PowerDubs_imp 7 638 07-21-2020, 01:59 AM
Last Post: Cobalt23_imp
  Power Commander V Brad14_imp 4 439 07-19-2020, 12:48 AM
Last Post: Brad14_imp
