Squealing when pulling clutch
Mine is RS 2017 and recently i have had squealing sound every time pulling clutch for gear change. I have lubricated the bolt but no luck. Anyone having the same problem and how to solve it. Thanks
hmm there should be no reason to squeal, it's hydraulic. Does it do it with the motor off? or just when the motor is running? What did you lubricate the pivot with?
Hmm if i remember right somebody put some WD40 by on the hand-lever there. And it was good after.... and a bit l have too the same sound by my DLX until now and not at the new EX
WD 40 is a short term fix for pivot squeal. Long term fix is to pull the blade, and pin, clean off the old stuff, apply a good quality grease like bearing grease and reassemble.
pics are gone but process is explained
http://www.cb1100forum.com/forum/showthr...p?tid=6755
When I did my summer trip in wet and rainy Scotland this year, the clutch lever started to squeal after a while. John helped me out with WD40 and it solved the problem. Being at home again I mounted foldable levers for each the brake and the clutch because I damaged one of it through a downfall of the bike. They were mounted with a good portion of grease and never did an annoying sound since then. If they will do, I repeat the grease thing.
Wisedrum
Ferret, it's quealing either motor on or off. I have lubricated the pivot with Liqui chain lub.
Thanks for the info, i'll try it out on weekend.
(11-15-2017, 12:54 AM)The ferret_imp Wrote: WD 40 is a short term fix for pivot squeal. Long term fix is to pull the blade, and pin, clean off the old stuff, apply a good quality grease like bearing grease and reassemble.
If it is the clutch lever squealing that should fix it. PLease let us know. I'm surprised it's happening on a new bike though. Musta got past the luber at the factory.
Yes Ferret. It even leaked at the head gasket as many posts discussed before regarding oil seapage or leakage Big Grin but i have got it fixed by applying a layer of sealant beneath the gasket. No more leak since then.
(11-15-2017, 01:16 PM)The ferret_imp Wrote: If it is the clutch lever squealing that should fix it. PLease let us know. I'm surprised it's happening on a new bike though. Musta got past the luber at the factory.
Head gasket or valve cover gasket?
"Squealing when pulling clutch"
I suggest tempering your enthusiasm.
Chip
  CLUTCH FLUID CHANGE SUPERCRUZ_imp 15 1,319 12-24-2025, 11:14 AM
  Replace clutch Lever Davidjill_imp 10 1,002 02-06-2025, 01:27 AM
  Clutch Plates finally going? misterprofessionality 12 1,084 11-22-2024, 07:49 AM
  Clutch fluid change CB1100@2013: photos valkyrie_rider_imp 0 250 02-13-2024, 10:27 AM
Last Post: valkyrie_rider_imp
  Clutch Fluid Wagonpeddler_imp 32 2,584 06-14-2023, 08:09 AM
Last Post: bvictory_imp
  Clutch Not Working Henrik_imp 7 659 04-24-2023, 06:43 PM
Last Post: Henrik_imp
  Clutch pull mpuhl_imp 4 519 02-21-2023, 10:48 AM
  Clutch slave cylinder gasket Maturecheese_imp 3 399 01-27-2023, 12:33 AM
Last Post: Maturecheese_imp
  brake & clutch adjusters The Gecko_imp 10 877 11-25-2022, 08:47 AM
  Clutch Lever Full Engagement odelegacy_imp 41 2,705 10-28-2022, 09:27 PM
