Grip install. Again. Grr.
Hi all,
I installed Oxford brand heated grips on my '13 two years ago. The heat works great. But I haven't found any adhesive to keep the throttle side in place.
I started by using the provided "Super Glue." It was fine until I used the heat and then the grips expanded and the glue broke loose.
Then I tried a "Rubber Cement" type of glue and it worked great until I turned on the heat and the glue softened up and the throttle side slipped on around.
I then tried "Wiring" the throttle side on (wrap the grip with wire and twist until tight) but that wasn't effective because the grip rubber on the Oxfords is too rigid to really squeeze tight on the throttle tube.
I am terribly sad.
So. Do any of you bright folks have a solution for me? Oxford folks are very friendly but not at all helpful.
And why haven't they come up with a simple system by which the throttle tube has small horizontal ridges molded in and grips with small grooves to match. No slip, no glue, so mess, no fuss. Maybe I can make my millions with this idea.
Any thoughts would be much appreciated.
LOL I've had Oxford heated grips on my ST for about a couple of years now. They work great. No slip on mine, as a matter of fact, I had to take a rubber mallet and pound the throttle side tube on as it was tight (even after sanding the inside of the tube) and the glue started setting up before I could get it slid all the way on. No way is it going to wiggle or slip. Figured if they ever quit working I'll never get them off and have to buy a new throttle tube.
Maybe some 2 part 5 minute epoxy? But if you ever wanted to replace the grips you too would have to buy a new throttle tube.
(03-23-2018, 12:04 AM)The ferret_imp Wrote: LOL I've had Oxford heated grips on my ST for about a couple of years now. They work great. No slip on mine, as a matter of fact, I had to take a rubber mallet and pound the throttle side tube on as it was tight (even after sanding the inside of the tube) and the glue started setting up before I could get it slid all the way on. No way is it going to wiggle or slip. Figured if they ever quit working I'll never get them off and have to buy a new throttle tube.
The provided super glue was a challenge as it does set up really fast and is very drippy and runny, so it was all over the place when I was done. My throttle tube must be thinner than the one on your bike because sliding the grip on was no trouble. Not lose but not tight.
Maybe epoxy is the answer.
Bicycle tire inner tube from skinny racing tires, rubber glove fingers and put on with soap?
(03-23-2018, 04:23 AM)max_imp Wrote: Bicycle tire inner tube from skinny racing tires, rubber glove fingers and put on with soap?
Meaning, put one of those items on first and then the grip over it?
Yup, first.
(03-23-2018, 04:29 AM)max_imp Wrote: Yup, first.
No adhesive at all?
From memory i used self-vulcanising tape and cleaned the grips first , but it took 3 times before it turned out the way i wanted, i would say if the surfaces are clean ( no talcon powder ) the tension of the small tube would be enough to grip the plastic to sit there for life, i am talking about those really skinny inner tubes on race bikes and maybe some sanding once they are on the grips, no glue.
Also there is a product called liquid tape and is used instead of electrical tape, available from electrical supplies, it is a thick plastic paint that can be applied with supplied brush to the tube, allowed to dry and then provides enough friction for the grips.
Then there is red gasket silicone that can be applied to the plastic tube, made to work up to 120* c.
I took the nuclear option and used a small bit of epoxy on those suckers. I think I'm good... until I need to pull them for some reason Confused
ROFL
  Delkevic 9" Oval Install Problems. jbird06_imp 4 487 06-11-2024, 08:25 AM
Last Post: devildogdoc_imp
  Install a 6-speed trans on a 2013? amacbeth_imp 37 3,446 02-21-2023, 12:22 PM
  17 tooth CS sprocket install, comments. Bike #12_imp 11 1,022 01-03-2022, 08:30 AM
  Tail light install problem iamheero_imp 9 754 11-27-2021, 02:58 AM
Last Post: Bazbro_imp
  Engine Guard Install Question? linuxology_imp 27 1,951 07-25-2020, 08:52 PM
  You can't do that, Panier install kennyw 32 2,104 03-19-2019, 02:53 AM
  Would love some input on the install of the factory heated grips. Tim_imp 2 347 05-06-2018, 03:08 AM
Last Post: Tim_imp
  Road Comet 2 Install letsjet_imp 20 1,387 02-12-2017, 05:51 AM
Last Post: ClassicVW_imp
  handle bar grip glue fishmitch_imp 20 1,223 09-05-2016, 05:33 PM
Last Post: Guth_imp
  Diy Bar end mirrors install Matt F._imp 5 479 04-18-2016, 11:24 PM
Last Post: Motogeezer1949_imp
