handle bar grip glue
im changing my rubber grips and was wondering what u guys suggest using for glue. thanx in advance
I dont use any glue. Just cut or blow the old grips off, squirt some contact cleaner in the new grip swish it around and slide it on really quick. Give it a few mins for the contact cleaner to dry up. Done.
cool, ferret. never would of thought of that. gonna go try it .
Hair spray works also. I have had it hold grips in place for up to two years.
ok guys, contact cleaner aint gonna work cause i already had cleaned old glue up. may try hairspray. do i need to use the kind that the spike guys use on their hair Clap
(02-20-2016, 01:21 AM)Ole_imp Wrote: Hair spray works also. I have had it hold grips in place for up to two years.
I went with hairspray too. Worked well.
When I put heated grips on the ST1300, the dealer service manager said if the grip is going to fit tight, use Pro-Honda grip cement. If it fits, well, not tight, use gel super glue. I used the Honda stuff.
Naturally, like most things, there appears to be more than one way to skin a cat. Disclaimer: I have 2 cats. Don't want to skin them Smile
Just had a call from the cats, popgun. They don't believe you.
Leftover clear spray paint (because it's going to ooze out), silicone seal or caulk or construction adhesive in a tube, whatever stuff you have leftover in the garage.
As long as it gives you time to slide on that sometimes stubborn grip and to rotate it into position then you're good to go.
Don't use that super glue stuff they include with grips, that stuff will setup too fast and you'll be cursing when the grip is stuck in the wrong position.
If you're a golfer and you regrip clubs you can use the tape and solvent method too.
Aloha,
Huladog
The Honda glue is basically a contact cement. After applying it to both surfaces it will set up. Before installing the grip, you are supposed to apply isopropyl alcohol liberally to allow the grip to slide on. You MUST move fast though.
And Cormanus--as much as those cats eat, they should be worried. Bet they taste like chicken! Smile
  Torque specs for handle bar clamp to triple clamp itstuantran_imp 8 656 07-11-2019, 10:16 PM
Last Post: itstuantran_imp
  Handle bar replacement/ Finally happened bike backed into or attempt to steal mustang462002_imp 7 451 05-10-2019, 12:00 PM
  Grip install. Again. Grr. Inhouse Bob 9 640 03-29-2018, 07:10 AM
  Torque Specs for Handle Bars ? Chapomis_imp 3 280 05-20-2016, 08:31 PM
Last Post: Chapomis_imp
  Grip won't stick to new knurled Renthal bar Ferrealls_imp 6 499 06-20-2015, 11:04 AM
Last Post: Ferrealls_imp
  Side-to-side play in throttle grip pechorin75_imp 28 1,795 02-25-2014, 08:56 AM
