Would love some input on the install of the factory heated grips.
Afternoon to you all, has any one here today ever installed the factory heated grips on a 2014. The instructions in step 18 have you pull hoses and relays and trays out of the way so you can get a wrench on the throttle cable as shown in the diagram for that step, mine isn't any place close to what they are showing with both the adjuster nut and the lock nut being bottomed out on bracket. Any idea why they have you do that and then put it all back together? If I make a major adjustment like that wont I need to go back in at the end and readjust it back to where it is now? (Providing of course its properly adjusted now).
Tim, did you see this thread, http://cb1100forum.com/forum/showthread.php?tid=7350 ?
(05-05-2018, 06:42 AM)Cormanus_imp Wrote: Tim, did you see this thread, http://cb1100forum.com/forum/showthread.php?tid=7350 ?
No I had not, I will take a look at it, thanks a lot. I think I worked my way past that, logic said if it isn't messed up don't screw with it, I have enough slack to manipulate the upper cable in place so I think were good to go now.
Thanks Again
Tim
  'Factory' high performance spark plugs PowerDubs_imp 17 1,475 10-23-2024, 02:50 PM
Last Post: rtmoto1
  Delkevic 9" Oval Install Problems. jbird06_imp 4 458 06-11-2024, 08:25 AM
Last Post: devildogdoc_imp
  Install a 6-speed trans on a 2013? amacbeth_imp 37 3,179 02-21-2023, 12:22 PM
  17 tooth CS sprocket install, comments. Bike #12_imp 11 960 01-03-2022, 08:30 AM
  Tail light install problem iamheero_imp 9 717 11-27-2021, 02:58 AM
Last Post: Bazbro_imp
  Factory Service Manual Download ??? markT_imp 24 1,872 10-14-2021, 09:30 AM
Last Post: furious_blue_imp
   Heated Grips on the EX michael1954 25 1,892 01-21-2021, 04:24 PM
Last Post: michael1954
  Africa twin manufacturing kumamoto factory max 11 819 09-30-2020, 12:41 PM
  Engine Guard Install Question? linuxology_imp 27 1,790 07-25-2020, 08:52 PM
  You can't do that, Panier install kennyw 32 1,909 03-19-2019, 02:53 AM
