Engine Guard Install Question?
Thinking of installing the stock Honda engine guards. Is it as simple as doing one side at a time and retightening the bolts? Do they need to be torqued or is tight enough good enough? Any tips/thoughts? I have never installed anything like this on a bike before.
The instructions that come with the OEM engine guards do a good job of explaining each step. You'll reuse some of your existing frame bolts on the upper portion of the frame and then use the smaller supplied bolts for the lower connection. One side at a time and take your time (which won't be much) and you'll get it done. The hardest part is getting the stock bolts out. I don't remember the size (14mm?) but you'll need a decent set of box wrenches and you'll want to secure the nut on one side and then turn the bolt on the other side. It'll take a bit of force but nothing too crazy. The lower frame bolts (10mm?) are easy enough but will also require securing the nut on one side as you tighten the bolt on the other side.
The guards come with brackets for the lower attachment. There is a slot opening where the bracket affixes to the guard then the bolts secure the bottom of the bracket. It'll make sense when you see it. You'll be working near your pipes so do the install while the bike is cold. I think you'll be happily surprised with how easy this will be and you'll be ready to tackle your next project.
Given the designed purpose of the guards and the fact that they are affixed directly to your frame, I highly recommend using a torque wrench. If you don't have one, hit up your neighbor or pick one up from Amazon. It'll come in handy in the future. If you go with a torque wrench, get the foot-pound wrench. They also have inch-pound wrenches that wouldn't be a bad idea to have but won't be needed for this mod. Don't feel bad asking how to use one either (you'll probably figure it out fine on your own). Good luck and post up some pics when you're done!
Edit: Oh, one other tip - Leave the bolts a little loose until you're sure you have everything lined up properly. It helps to have the top affixed loosely while you position the bottom bracket. Then get the bottom bracket bolts affixed loosely. Finally, go back to the top and tighten the bolts to the specified measurement and end with tightening the bottom bolts to their specified measurement.
excuse my ignorance, but for securing the nut on the other side would it require another person? Also do I complete one side to include torquing before starting the other side?
No worries. You won't need anyone else. You just position your wrench over the nut with one hand to keep it from spinning while you loosen and remove the bolt with a separate wrench in your other hand. The largest bolt is only a few inches long.
As far as when to use the torque wrench, that's up to you. It doesn't really matter. Each side is completely independent of the other. I would suggest completely finishing one side before moving on to the other just so you don't inadvertently forget to do one side.
If any of this is still confusing, let me know and I'll snap a few pics for you to show you what I'm talking about. That will have to wait, however, until tomorrow at the earlies. Hope this helps!
Installed mine yesterday. The Honda Brand Engine guards are pretty self explanatory as MG said. 14 mm for the lower of the two frame bolts. 8mm for the clamp bolt and 10 mm for the clamp nut.
The only thing that threw me is that the two sides are different shapes. The curvy one goes on the right.
As MG pointed out, a project like this empowers you to do much more.
George
Mine did not come with instructions.... Found them online for any other newbies like myself....
http://powersports.honda.com/documentum/...GC-N20.pdf
(03-24-2015, 04:15 AM)linuxology_imp Wrote: Mine did not come with instructions.... Found them online for any other newbies like myself....
And? How'd it go? You get them on there ok? Let's see!
Hope to do mine this weekend.
I'm a firm believer in learning from others' mistakes, so,
Tell me, the longer of the two bolts seems to be one of the engine mounting bolts; do I need to support the engine's weight when removing it, or do the others keep it in position?
Takes 10 min to install, I don't even remember if mine had instructions being its so simple you don't need them. Very self explanatory, if you can turn a wrench then you can do it. If you never touched a wrench before then ask someone who has. I used some blue locktite on the lower bolt for the frame clamp. They look great on the bike and are well made.
(03-27-2015, 07:56 PM)Insolentsquid_imp Wrote: Hope to do mine this weekend.
Just take it out, install and put back in one side at a time. Don't need to support anything. Very simple, just remove the one bolt, put the guard in place, put bolt back in and put clamp on bottom then button up nice and tight. Maybe use a little blue locktite on the bottom clamp bolt and has it.
Would these be as good as SW Motech engine guards to mount highway pegs?
  Delkevic 9" Oval Install Problems. jbird06_imp 4 481 06-11-2024, 08:25 AM
Last Post: devildogdoc_imp
  Install a 6-speed trans on a 2013? amacbeth_imp 37 3,362 02-21-2023, 12:22 PM
  Question on replacing engine side cover Ollie 11 825 01-10-2022, 11:21 AM
Last Post: Ollie
  17 tooth CS sprocket install, comments. Bike #12_imp 11 1,012 01-03-2022, 08:30 AM
  Tail light install problem iamheero_imp 9 745 11-27-2021, 02:58 AM
Last Post: Bazbro_imp
  Ebay radiator guard rattles... boynton6spd_imp 9 742 06-09-2021, 03:45 AM
Last Post: michael1954
  Location of Engine Number on Engine? cb1100_dude_imp 2 335 05-29-2019, 01:44 PM
Last Post: cb1100_dude_imp
  "13 muffler guard HBFL_imp 2 329 04-16-2019, 08:06 AM
  You can't do that, Panier install kennyw 32 2,046 03-19-2019, 02:53 AM
  Would love some input on the install of the factory heated grips. Tim_imp 2 346 05-06-2018, 03:08 AM
Last Post: Tim_imp
