Threads: 42
Likes Received: 5 in 4 posts
Likes Given: 3
I just placed an order for 10 license plate brackets. I figured if I make one, someone else would want one as well. I'm also including the dimensions if someone wants to make their own.
My cost is $15 each plus shipping. Anyone want one?
Threads: 45
Kennyw, Nicely done, and I admire your mechanical drawing/drafting skills! What is the material, thickness, and finish? Price is very reasonable, as I have a Joker Machine 1/8" thick hard black anodized aluminum LP backing plate on my 2017. If I did not already have that base covered, I would be all over your nice clean design.
Likes Received: 605 in 271 posts
Likes Given: 784
Threads: 42
Likes Given: 3
The finish will be bare aluminum, DA sanded, good for painting or powdercoating when you receive it. I would not recommend leaving it bare.
Thickness is .100" and any grade aluminum should be fine in this application.
Threads: 119
Likes Received: 809 in 341 posts
Likes Given: 809
Nice work Kennyw...was there a spacer that you had to use as well? Since it's aluminum, what's the issue with leaving it bare?
Threads: 42
Likes Given: 3
There will be a pair of spacers required for the top two mounting bolts. I will detail out the assembly hardware you need to buy separately and include instructions in with the plate when it is mailed. The hardware is all easy to find at local hardware stores.
If you leave it bare, it will eventually corrode and look bad (though barely visible other than the reflection in the fender). No telling how long that would take, but I would recommend painting with a clearcoat at a minimum.
Threads: 3
Do these fit the 2013/2014 fenders too?
Threads: 42
Likes Given: 3
No, but I could get some made.
Threads: 32
If you do decide to make some for 2014 models, I will purchase one.
Threads: 42
Likes Given: 3
I just checked and my guy hasn't cut parts yet. I'll change the order to include 5 of the the 2013-14 brackets.
