Threads: 2
So, I've now had two oil filters vibrate loose while running the bike, and start dripping oil, while running, which gets all over the Yosh exhaust and the rear tire
This is Highly irritating, not to mention dangerous. I always do my own oil on all my bikes, and hand tighten the oil filters to ~the same tension. I've NEVER had one vibrate loose in thirty plus years before this CB, now I've had two within six months.
Yes, I checked there is not an extra gasket, and I did oil the gasket lightly before spinning it on.... Dang Gonna have to wire the fuggin thing.
Anyone else have this?
Likes Given: 140
Sure you are putting it on tight enough? No one is reporting this and some guys are putting a LOT of miles on their bikes.
Likes Received: 171 in 69 posts
Likes Given: 87
There's a thread here [url=http://cb1100forum.com/forum/showthread.php?tid=2776%20]Torque Settings (oil change)that says the torque setting is 13ft lb. for the filter. You might want to try tightening the filter to spec before engaging in further troubleshooting.
I have 21,000 leak-free miles on my bike and also have not seen this particular complaint on the forum before this. Good luck and I hope the issue is solved quickly.
Threads: 186
Always tighten by hand and then a slight snug with the filter wrench, never a problem. In 50 years of doing my own oil changes, I've never had one vibrate loose.
Strange indeed.
Likes Received: 605 in 271 posts
Likes Given: 784
I do 6 oil changes a year at least on my two bikes... hand tighten first contact plus 1/2 to 3/4 turn of the filter (which is more than one would think) usually takes 2 hands. Never had one leak or vibrate loose.
Threads: 2
Y'all are describing my tightening procedure exactly. hand tighten, then another 1/2 turn.
That's what surprises me, I've also NEVER had one back out before, and this is far from my first transverse four, I've owned at least five other CB 750's in my life, a Suzuk, a Yamaha (or three) not to mention the OldWing, Silverwing(CX), dirt bikes, etc etc.
These were both K&N oil filters, a brand I don't usually buy, but couldn't find the hondaline or fram, and didn't think it would make a difference.... Dunno.
It always happens on the interstate when I'm rolling between 70-90 commuting to work 25 miles each way. (always, I mean both times)
Likes Given: 784
I only use Honda filters, (which I buy by the 6 pack), but wouldn't think that would make a difference. Lots of people prefer the K&N's for the 17 mm nut on top.
http://motorcycleoilfiltersonline.com/ho...kn303.html (3 pack of K&N $33.... 3 pack of Honda oem $25)
http://www.bikebandit.com/oem-parts/deta...gQodmgcCXg
http://www.partzilla.com/parts/detail/ho...gQodz94MNA
Threads: 2
Thanks for the link Ferret, I'll order a sixer of the honda filters and will update.
The sixer link is the correct oil filter?
Hopefully a 'This never happened again' update.
Likes Given: 140
I'm looking at one right now still in the wrapper
. 15410-MFJ-D01
Bought from the dealer. Might want to order some washers for the drain plug too...
Threads: 85
Likes Given: 129
I had a MINOR leak after one of my oil changes, but I know that was my fault. I checked and sure enough, the filter wasn't tight enough. I just tightened it up a bit, cleaned off the oil from the engine, and went on my way. Hasn't happened again since.
