Installing RLETs on a CB1100 (All Models)
Rightfully so, I was strongly encouraged to install RLETs on my motorcycle. Finding the OEM part was easy enough, but I did have some trouble sourcing an installation procedure which did not involve cursing, heartache, and bloody fingers.
The procedure I used below was definitely improvised. I suspect there is a truly professional procedure which is better. Feel free to mock this improvisation and set the record straight.
That said, here is how I managed to get two RLETs installed in about an hour.
Step 1: Order twice as many RLETs as you plan to install. It is easy to split a seam no matter how you install them. I ordered mine from Partzilla. The compatible OEM Part Number is 95010-16001. I recommend you ignore the warning about the part not fitting a CB110. This OEM part will fit.
https://www.partzilla.com/product/honda/95010-16001
Step 2: When you receive the RLETs, unwrap the package and confirm that all of the rubber seams are in tact. Take a 5/16 socket and insert it into the center of the RLET:
[Image: f8439174f8ede8289e0bc44ace3ca98a.jpeg]
[Image: 2ced1ba17376a38729e229aad9484f80.jpeg]
Step 3: Heat some water in a glass until it is almost boiling. Place the RLET into the glass. Let it it “simmer” for 15 minutes. Heat more water and replace the water in the glass. Let the RLET “simmer” for another 15 minutes. Be careful with the glass, water, and RLET. Everything absorbs heat and can burn you.
[Image: 5fb5ea1c91cc7532b2b046dc34141f79.jpeg]
Step 4: Remove the RLET from the water. Remove the 5/16 socket from the RLET. Spray an aerosol based oil like PAM or something similar into the opening of the RLET. Try to keep the oil “inside” the RLET. Do everything you can to keep the oil away from the rubber on the RLET which faces outward. Oil on the outside of the RLET will make it difficult to push down onto the handlebar in the next step:
[Image: f41bc215f60ff330dabdba8a1d12eac4.jpeg]
[Image: 5160dc8ea33f15f047977236cc62780d.jpeg]
Step 5: Take a good pair of needle nose pliers and “pry” open the RLET. This task requires as much “feel” as strength. Open slowly, stretching the already softened rubber. When you have an adequate opening, slip it over the lever where you want to place the RLET. Note that you will only be able to get the RLET on partially. Once it is “halfway” on the handlebar, withdraw the needle nose plowers and use your hands to finish pushing the RLET into its final position. When the RLET cools, it will return to its original shape. Like all parts on our CB1100s, Honda used only the best rubber to make the RLETs.
[Image: bece6f1397371f22496e095c02d2111b.jpeg]
[Image: 48d25433f48e3463ba61402936d62b3e.jpeg]
Hope these notes are useful. I welcome any suggestions for improving them or an existing post which has a better approach.
Take care,
David
Easy RLET installation, using a sheep castrator
http://cb1100forum.com/forum/showthread....castration
(09-12-2024, 03:27 PM)Karidis_imp Wrote: Easy RLET installation, using a sheep castrator
Definitely easier.
Although I own a horse farm with plenty of animals and grew up hunting, there is something about using a castration tool for anything which makes me a little queasy. Smile However, if I found myself on an assembly line installing RLETs, I am sure I would get over it. Thanks for the video and the creativity. Truly impressive! David
I just put on rubber gloves for good grip, spray some lubricant, like armor-all inside the RLET and shove it on.
No longer a Padawan you are Rd! The ring is purring Smile
I think member Nemo holds the record for RLET installation. Something like 10 seconds.
>> +1 <<
Ferret will be along shortly to sort out the angel.
Very nice David, and another angel get's their wings!
I did mine the easy way...in Dec 2012 when I bought my 2013 bike, I had the shop put them on before I picked it up.
Then did the same when I traded the 13 in on the 14 Deluxe lol.
(09-12-2024, 10:59 PM)The ferret_imp Wrote: Very nice David, and another angel get's their wings!
Well, I stand before my betters humbled and amused. Between castration devices, some kind of white magic, and outsourcing, there appears to be easier methods to install RLETs than what I did by looking in my tool box! Smile Kidding aside, thanks for the not so gentle push to get it done. The motorcycle looks nicer with them. Have a great weekend.
David, your reverence for the importance of the RLETs will put you in good standing here on the forum. Be sure to keep a good supply of rubber preservative in your detailing kit. Can't let them get dry and cracked now, after all of that work.
  CEL on after installing new batterie on 2017 Houtman_imp 8 634 12-06-2020, 02:07 PM
  Fuel Tanks & Seats on Different Models Cormanus 16 1,278 10-27-2020, 04:42 AM
  Weight of the OEM Wheels on the 2013/2014 std models? misterprofessionality 7 564 04-04-2019, 09:24 PM
  K&N Filters: use grease when installing Ulvetanna_imp 4 488 06-26-2016, 01:48 PM
Last Post: Ulvetanna_imp
  Help installing chic rear fender MikeOxbig_imp 4 398 09-28-2015, 05:27 AM
Last Post: Motogeezer1949_imp
  Problem installing aftermarket exhaust MrTim_imp 12 776 09-08-2014, 08:38 PM
  Gear ratio 13 & 14 models Ridem32_imp 18 1,005 06-27-2014, 03:01 PM
Last Post: Ridem32_imp
