Handlebar clamps
Hi all,
Are the handlebar clamps on my '13 CB1100 specific to the model or are they generic?
I want to change the clamps from silver to black but I know a genuine Honda parts will cost a pretty penny.
I'm fitting a black Renthal 758 bar so want matching clamps.
One thing to consider, and it may not be a big deal to you, is that the clamp has an oblong mounting surface on the bottom. Most aftermarket clamps will have a round bottom mounting surface. That means if you used something else, you may have a round clamp sitting on an oblong mounting area on the triple tree. I’d have a problem with that visually but I’m pretty ocd.
Rustoleum Satin Black could be your friend here. I’ve done just as you are looking to, and it came out perfect. Depending on the gloss level of the bars, maybe semi-gloss.
Cool. Thanks for the info.
The CB1100 handlebar clamps are specific to CB1100s, at least in the US market. They top bridge clamp (fork top clamp) has pressed-in rubber bushings, so the handlebar clamps have a long, unthreaded shank portion that is a snug fit in the bushing's inner sleeve.
There are other bikes that use loose, replaceable rubber bushings, but the shank portion maybe longer or different diameter.
As Gone in 60 said, spray paint is your best bet.
According to Babbits online OEM Honda parts, a set of silver upper and lower clamps would run $75. Two options for you other than paint, that would be more durable, are Powder Coat, and black Aluminum Anodize. The guy that does my occasional Powder Coat would charge his minimum which is $20, for a clamp set. Aluminum Anodize in black would not be very expensive for a clamp set either, but would take a little research to find a shop that does it. Any of these options are obviously a lot less than new parts, if in fact they are even available in black.
The lower half of the clamp has the sleel shaft cast into it, and you can't anodize steel or iron.
My Bad, I did not consider the steel stud, good catch Pekingduck! Powder Coat would work though, with the stud taped off during application.
  Knocking noises; vibrations in the handlebar; oil sipping at valve lid gasket TheLegend 47 5,551 11-16-2025, 12:01 PM
Last Post: TheLegend
  CB1100 EX CA K handlebar switches sprint 7 590 02-25-2025, 10:36 PM
Last Post: sprint
  Stock handlebar measurements misterprofessionality 5 555 04-12-2022, 05:47 AM
  Handlebar: passage of cables pericleromano_imp 7 596 11-03-2021, 02:50 AM
Last Post: j3gq_imp
  Handlebar bolts torque value? (CB1100RS -18) Olof_imp 3 395 04-03-2021, 01:35 AM
  Handlebar Weights dave 9 608 01-29-2020, 02:11 AM
  Rubber Spacers Handlebar Mounts jermo47_imp 8 545 05-22-2019, 12:58 AM
Last Post: jermo47_imp
  Handlebar Clamp Bolt size? Nappi185_imp 7 655 08-08-2017, 01:49 PM
Last Post: Nappi185_imp
  Handlebar Top Clamp Variance Aka Tsubasa_imp 11 947 07-29-2017, 11:00 AM
Last Post: Aka Tsubasa_imp
  Handlebar And Control Alignment Aka Tsubasa_imp 2 245 07-12-2017, 06:38 AM
